Belkin BoostCharge USB-C PD 3.0 PPS Wall Charger 25W
Quicklinx: HBPBWS00 Mfr#: WCA004myWH
Device Type: All
Type: Charger
Product Range: Belkin BoostCharge
Product Model: [N/A]
17 In Stock
£10.48 ex VAT
£12.57 inc VAT
Get optimal charging speeds for both Samsung smartphones and iPhone with this USB-C charger. It's USB-C PD 3.0 certified with PPS technology, giving your device a safe charge with the right amount of power, all in a compact, travel-ready design.
  • Optimized for Samsung and iPhone
    Get optimal charging power with this 25W USB-C PD 3.0 PPS wall charger. This fast and universal charging solution is optimized for both iPhone and Samsung smartphones, as well as other USB-C PD enabled devices.
  • Dynamic power
    Safely recharge your phone faster than ever with the intelligence of Programmable Power Standard. PPS technology enables the power supply to dynamically adjust its output based on the device it's connected to, delivering the exact amount of power needed for the ideal charge.
  • USB-C PD 3.0 certified
    The PPS wall charger is also USB-C PD 3.0 certified, which means it's safe, compliant, and meets required specifications for your compatible device.
  • Compact and travel-ready
    All the power and speed you'll need in a compact, travel-ready design.
Belkin BoostCharge power adapter - 24 pin USB-C - 25 Watt
Power adapter
4.3 cm x 7.3 cm x 2.6 cm
White
Output Connector Type
24 pin USB-C
Fast Charge Technology
Power Delivery 3.0
Power Provided
25 Watt
Power adapter
Mobile phone
4.3 cm
7.3 cm
2.6 cm
Enclosure Colour
White
Output connectors
24 pin USB-C
Power Provided
25 Watt
Power Delivery 3.0
Programmable Power Standard (PPS)
Device Type: All
Type: Charger
Brand: Belkin
