Belkin BoostCharge Pro - 2-in-1 Magnetic Wireless Charging Pad
Quicklinx: HYR0WS00 Mfr#: WIZ021myBK
The Belkin BoostCharge Pro 2-in-1 wireless charging pad is designed for both cellular phones and wireless earphones, featuring Power Delivery 3.1 for fast and efficient charging. Its magnetic Qi2 compatibility enhances the charging experience for MagSafe enabled devices, providing a secure connection every time.
Crafted with the environment in mind, the BoostCharge Pro is made from 60% recycled post-consumer plastic, making it a choice that benefits both your devices and the planet. The pad's user-friendly design includes a non-slip base, case compatibility up to 3 mm, and an LED indicator for charging status at a glance. With the inclusion of a 1.5 m USB-C to USB-C cable, setting up your charging station is straightforward. Choose the Belkin BoostCharge Pro 2-in-1 for a seamless and sustainable charging solution.
  • Efficient charging
    Experience the convenience of fast wireless charging with the Belkin BoostCharge Pro 2-in-1. Its Power Delivery 3.1 technology ensures your devices get the power they need quickly, supporting up to 15 W for wireless charging pads and 30 W for the AC power adapter.
  • Designed for compatibility
    Tailored to support a wide range of devices, this wireless charging pad is compatible with both cellular phones and wireless earphones. Its magnetic Qi2 feature enhances the charging experience for MagSafe compatible devices, ensuring a secure and efficient power transfer.
  • Eco-friendly choice
    Committed to sustainability, the Belkin BoostCharge Pro 2-in-1 is made of 60% recycled post-consumer plastic. Choosing this product not only benefits your charging needs but also contributes to a healthier planet.
  • User-friendly design
    With features like a non-slip base, case compatibility up to 3 mm, and an LED indicator, this wireless charging pad is designed for ease of use. Its magnetic Power Profile (MPP) pad ensures your device stays in place while charging.
Belkin BoostCharge Pro 2-in-1 wireless charging pad - magnetic with Qi2 - + AC power adapter - 15 Watt
Wireless charging pad + AC power adapter
Mobile phone, wireless earphones
16.31 cm x 8.18 cm x 1.5 cm
420 g
Max Electric Current
3 A
Fast Charge Technology
Power Delivery 3.1
Wireless Charging Standards
Qi2
Power Provided
15 Watt
Power Device Details
Wireless charging pad - wireless pad - 15 W , Wireless charging pad - wireless pad - 5 W , Wireless charging pad - 24 pin USB-C - 5 W , AC power adapter - 24 pin USB-C - 30 W
Cables
USB-C to USB-C cable - 1.5 m
Product Recycled Content
60 % - made of recycled post-consumer plastic
16.31 cm
8.18 cm
1.5 cm
420 g
Enclosure Colour
Input Connectors
24 pin USB-C
Input Connectors Qty
1
Power Provided
15 Watt
3 A
Wireless charging pad: wireless pad - 15 W , Wireless charging pad: wireless pad - 5 W , Wireless charging pad: 24 pin USB-C - 5 W , AC power adapter: 24 pin USB-C - 30 W
Wireless Charging
Qi2
Power Delivery 3.1
AC Power Adapter Included
MagSafe Compatibility
LED indicator, case compatible (up to 3 mm), fast wireless charging, Magnetic Power Profile (MPP) pad, non-slip base
Equipment Protection Value
1500 British Pounds
Material
Plastic
RoHS, REACH
