Charge your Samsung or other smartphone from 0 to 50% in 26 minutes with this 25W USB-C PD 3.0 PPS wall charger. Upgrade your standard in-box power supply with a universal USB-C PD 3.0 certified charger that gives an optimal charge for newer Samsung, Google, and other smartphones in a compact and travel-ready design. It is equipped with PPS technology which allows optimized charging with compatible devices by dynamically negotiating the best charging voltage, delivering up to 25W for Samsung smartphones and 20W for other smartphones.
Optimized for Samsung and iPhone
Get optimal charging power with this 25W USB-C PD 3.0 PPS wall charger. This fast and universal charging solution is optimized for both iPhone and Samsung smartphones, as well as other USB-C PD enabled devices. -
Dynamic power
Safely recharge your phone faster than ever with the intelligence of Programmable Power Standard. PPS technology enables the power supply to dynamically adjust its output based on the device it's connected to, delivering the exact amount of power needed for the ideal charge. -
The PPS wall charger is also USB-C PD 3.0 certified, which means it's safe, compliant, and meets required specifications for your compatible device. -
Compact and travel-ready
All the power and speed you'll need in a compact, travel-ready design.
 - Belkin BoostCharge power adapter - 24 pin USB-C - 25 Watt
- Product Type
 - Power adapter
 - 4.3 cm x 7.3 cm x 2.6 cm
 - White
- Output Connector Type
 - 24 pin USB-C
- Fast Charge Technology
 - Fast Charge, Power Delivery 3.0
- Power Provided
 - 25 Watt
- Cables
 - USB-C cable - 1 m
- Product Type
 - Power adapter
- Designed For
 - Mobile phone
 - 4.3 cm
 - 7.3 cm
 - 2.6 cm
- Enclosure Colour
 - White
- Input Connectors
 - Power BS 1363
- Input Connectors Qty
 - 1
- Output connectors
 - 24 pin USB-C
- Power Provided
 - 25 Watt
 - Programmable Power Supply (PPS)
- Equipment Protection Value
 - 2500 British Pounds
- Cables Included
 - USB-C cable - 1 m
