Charge your iPhone or Samsung smartphone from 0-50% in 30 minutes with this 25 W USB-C PD 3.0 PPS Wall Charger. Upgrade your standard in-box power supply with a universal USB-C PD 3.0 certified charger that gives an optimal charge for newer iPhone and Samsung models in a compact and travel-ready design. Equipped with PPS technology which allows optimized charging with compatible devices by dynamically negotiating the best charging voltage, delivering up to 25 W for Samsung smartphones and 20 W for iPhone.
Optimized for Samsung and iPhone
Get optimal charging power with this 25 W USB-C PD 3.0 PPS Wall Charger. This fast and universal charging solution is optimized for both iPhone and Samsung smartphones, as well as other USB-C PD enabled devices. -
Dynamic power
Safely recharge your phone faster than ever with the intelligence of Programmable Power Standard. PPS technology enables the power supply to dynamically adjust its output based on the device it's connected to, delivering the exact amount of power needed for the ideal charge. -
A PPS Wall Charger is also USB-C PD 3.0 certified, which means it's safe, compliant, and meets required specifications for your compatible device. -
Compact and travel-ready
All the power and speed you'll need in a compact, travel-ready design.
- Belkin BoostCharge power adapter - PPS technology - USB-C - 25 watt
- Product Type
- Power adapter
- Designed For
- Mobile phone
- 4.3 cm x 7.3 cm x 2.6 cm
- Black
- Output Connector Type
- USB-C
- Fast Charge Technology
- Power Delivery 3.0, Fast Charge
- Power Provided
- 25 watt
- 2-year warranty
- Product Type
- Power adapter
- Designed For
- Mobile phone
- 4.3 cm
- 7.3 cm
- 2.6 cm
- Enclosure Colour
- Black
- Output connectors
- 24 pin USB-C
- Power Provided
- 25 watt
- RoHS
- Limited warranty - 2 years
