Belkin BoostCharge 25W PD PPS Wall Charger - Black
Quicklinx: J79KWS00 Mfr#: WCA004vfBK
£16.59 ex VAT
£19.90 inc VAT
Charge your iPhone or Samsung smartphone from 0-50% in 30 minutes with this 25 W USB-C PD 3.0 PPS Wall Charger. Upgrade your standard in-box power supply with a universal USB-C PD 3.0 certified charger that gives an optimal charge for newer iPhone and Samsung models in a compact and travel-ready design. Equipped with PPS technology which allows optimized charging with compatible devices by dynamically negotiating the best charging voltage, delivering up to 25 W for Samsung smartphones and 20 W for iPhone.
  • Optimized for Samsung and iPhone
    Get optimal charging power with this 25 W USB-C PD 3.0 PPS Wall Charger. This fast and universal charging solution is optimized for both iPhone and Samsung smartphones, as well as other USB-C PD enabled devices.
  • Dynamic power
    Safely recharge your phone faster than ever with the intelligence of Programmable Power Standard. PPS technology enables the power supply to dynamically adjust its output based on the device it's connected to, delivering the exact amount of power needed for the ideal charge.
  • USB-C PD 3.0 certified
    A PPS Wall Charger is also USB-C PD 3.0 certified, which means it's safe, compliant, and meets required specifications for your compatible device.
  • Compact and travel-ready
    All the power and speed you'll need in a compact, travel-ready design.
Belkin BoostCharge power adapter - PPS technology - 24 pin USB-C - 25 Watt
Power adapter
4.3 cm x 7.3 cm x 2.6 cm
Output Connector Type
24 pin USB-C
Fast Charge Technology
Power Delivery 3.0, Fast Charge
Power Provided
25 Watt
Power adapter
Mobile phone
4.3 cm
7.3 cm
2.6 cm
Enclosure Colour
Output connectors
24 pin USB-C
Power Provided
25 Watt
RoHS
Brand: Belkin
