Belkin BOOST UP Wireless Charging Stand 10W - Black
Quicklinx: DXT7WS00 Mfr#: F7U052myBLK
Fastest wireless charging for your Qi-enabled devices has arrived. The BOOST?UP Wireless Charging Stand 10W delivers 10-watts for fastest charging and offers optimal wireless charging for iPhone X, iPhone 8/8 Plus, Samsung, LG, Sony and other Qi-enabled devices. Choose from four different color finishes to find the perfect color for your space.
BOOST?UP Wireless Charging Stand 10W offers up to 10-watt wireless charging to optimally charge any Qi-enabled smartphone. This higher wattage means faster charging than 5-watt wireless chargers and standard 5-watt wall chargers typically provided with the smartphone.
An original, thoughtful design makes it easy to align your device for fastest wireless charging in either landscape or portrait mode. From browsing a web page to watching a movie, it's easy to continue using your phone while you charge.
Qi is an established, evolving wireless charging standard owned by the Wireless Power Consortium (WPC). Their goal is to deliver wireless charging easily and safely, while ensuring compatibility across all devices that bear the Qi logo. All Belkin wireless chargers are developed to meet the Qi wireless charging standards as laid out by the Wireless Power Consortium. As a result, this fully Qi-certified wireless charger is compatible with all Qi-enabled devices.
Specifically engineered to optimize performance for all Qi-enabled smartphones, the BOOST?UP Wireless Charging Stand 10W not only charges at fastest possible speed but protects phone functionality while charging. Premium shielding and precision resistors found within this wireless charger minimize interference, ensuring battery life and critical phone functions such as network signal, touchscreen, Wi-Fi, Bluetooth and LTE are not disrupted.
  • Fastest wireless charging?engineered for QI
    Fastest wireless charging for your Qi-enabled devices has arrived. The BOOST UP Wireless Charging Stand 10W delivers 10-watts for fastest charging and offers optimal wireless charging for iPhone X, iPhone 8/8 Plus, Samsung, LG, Sony and other Qi-enabled devices. Choose from four different color finishes to find the perfect color for your space.
  • Save time with fastest wireless charging
    BOOST UP Wireless Charging Stand 10W offers up to 10-watt wireless charging to optimally charge any Qi-enabled smartphone. This higher wattage means faster charging than 5-watt wireless chargers and standard 5-watt wall chargers typically provided with the smartphone.
  • Charge in landscape and portrait mode
  • Universal compatibility
  • Optimized for better performance
    Specifically engineered to optimize performance for all Qi-enabled smartphones, the BOOST UP Wireless Charging Stand 10W not only charges at fastest possible speed but protects phone functionality while charging. Premium shielding and precision resistors found within this wireless charger minimize interference, ensuring battery life and critical phone functions such as network signal, touchscreen, Wi-Fi, Bluetooth and LTE are not disrupted.
  • LED light indicates proper charging
    A soft LED light indicates when your phone is correctly aligned on the pad and charging. The light has been designed to not disrupt your atmosphere or interfere with sleep. When you see the white light, your device is charging optimally.
  • Foreign object detection
    An LED light alerts you to foreign objects, such as keys or coins, on the wireless charger that could affect charging. Foreign object detection (FOD) helps to prevent the charger emitting unnecessary power and heat that could damage your smartphone and other heat-sensitive items. Placing magnetic mounts, metal cases or other objects between your phone and the charger might reduce performance or damage magnetic strips or RFID chips like those found in some credit cards, security badges and passports. If your case holds any of these sensitive items, remove them before charging or make sure they aren't between the back of your phone and the charger.
  • Case compatibility
    Charge without removing your case. The BOOST UP Wireless Charging Stand 10W is engineered to work with lightweight plastic cases up to 3mm (not compatible with metal cases).
Belkin BOOST UP wireless charging stand - 10 Watt
Wireless charging stand
Midnight
Wireless Charging
Wireless Charging Standards
Qi
Power Provided
10 Watt
Mobile phone
Enclosure Colour
Midnight
Power Provided
10 Watt
Wireless Charging
Qi
Power adapter
Qi
