Belkin BOOST UP CHARGE Wireless Charging Pad 15W (with Power Supply) - White
Quicklinx: G5SFWS00 Mfr#: WIA002myWH
Type: Wireless Charger
£28.32 ex VAT
£33.98 inc VAT
Designed to deliver fast wireless charging for the latest smartphones, the 15W BOOST?CHARGE Wireless Charging Pad couldn't be easier to use. Unclutter your bedroom, office, or kitchen counters by going wireless - just place your phone on the pad and start charging instantly. LED light indicators and non-slip surface keep your phone charging correctly, and a 24W Quick Charge 3.0 power supply unit is included.
Charge without removing your case. Belkin’s BOOST?CHARGE Wireless Charging Pad is engineered to work with lightweight plastic cases up to 3mm.
Power any Qi-enabled device using this single charger. The BOOST?CHARGE Wireless Charging Pad 15W has been engineered to fast charge Apple, Samsung, and Google smartphones while delivering 5W to all other Qi-enabled devices.
Constant calls and texts? No problem. The nonslip material helps to grip your iPhone, keeping it safely in place while charging.
  • Cut the cord with 15W of power
  • Case compatible up to 3mm
  • Universal QI compatibility
  • LED indicates charging status
    Green light confirms safe charging, amber light warns that a foreign object has been detected, red light indicates that your phone is not charging.
  • Non-slip material
  • Included power supply
    A 24W Quick Charge 3.0 power supply unit is included.
Belkin BoostCharge wireless charging pad - + AC power adapter - 15 Watt
Wireless charging pad + AC power adapter
9.5 cm x 9.5 cm x 1.55 cm
White
Fast Charge Technology
Qualcomm Quick Charge 3.0
Wireless Charging Standards
Qi
Power Provided
15 Watt
Power Device Details
AC power adapter - 24 W
Mobile phone
9.5 cm
9.5 cm
1.55 cm
Enclosure Colour
White
Power Provided
15 Watt
AC power adapter: - 24 W
Wireless Charging
Qi
AC Power Adapter Included
LED indicator, FOD (Foreign Object Detection), case compatible (plastic, up to 3 mm), non-slip surface
Power supply
Qi
Brand: Belkin
