Belkin BOOST UP CHARGE Wireless Charging Pad 10W
Quicklinx: G5S7WS00 Mfr#: WIA001btWH
Type: Wireless Charger
£14.03 ex VAT
£16.83 inc VAT
FAST WIRELESS CHARGING MADE SIMPLE
Fast wireless charging up to 10 watts so you always safely get the fastest possible wireless charge. Just lay your phone onto the pad for a quick and easy power boost.
UNIVERSAL QI™ COMPATIBILITY
Power any Qi-compatible phone using this single charger. The BOOST?CHARGE Wireless Charging Pad 10W has been engineered to charge Apple and Samsung smartphones at the fastest possible speed while delivering 5 watts to all other Qi-enabled devices.
CASE COMPATIBLE UP TO 3MM
Charge without removing your case. Our BOOST?CHARGE Wireless Charging Pads are engineered to work with lightweight plastic cases up to 3mm.
LED LIGHT INDICATES SAFE AND SUCCESSFUL CHARGING
Foreign objects like keys and coins can disrupt your charge and even lead to wireless chargers emitting unnecessary power that can melt or damage your belongings. Charge with confidence as a white LED light indicates your phone is properly aligned and charging, while an amber light alerts you to the presence of a foreign object. The light is specially designed to not disrupt the surrounding environment.
  • Fast wireless charging made simple
  • Universal QI compatibility
  • Case compatible up to 3mm
    Charge without removing your case. The BOOST?CHARGE Wireless Charging Pads are engineered to work with lightweight plastic cases up to 3mm.
  • LED light indicates safe and successful charging
  • Quick Charge 3.0 wall charger is included
    The Quick Charge 3.0-compatible wall charger and cable ensure optimal charge to your wireless charger. You can also connect Quick Charge-compatible devices to the wall charger using the included cable to power up from zero to 80% in just 35 minutes.
Belkin BoostCharge wireless charging pad - 10 Watt
Wireless charging pad
1.33 cm
Diameter
9 cm
74 g
White
Image Colour Disclaimer
The displayed product image may be a different colour
Wireless Charging Standards
Qi
Power Provided
10 Watt
Cables
USB type A to micro-USB type B cable - 1.2 m
Mobile phone
1.33 cm
Diameter
9 cm
74 g
Enclosure Colour
White
Power Provided
10 Watt
Wireless Charging
Qi
LED indicator, FOD (Foreign Object Detection), case compatible (plastic, up to 3 mm)
Equipment Protection Value
2000 Euros
USB-IF, MFI, Qi
Brand: Belkin
