FAST WIRELESS CHARGING MADE SIMPLE
Fast wireless charging up to 10 watts so you always safely get the fastest possible wireless charge. Just lay your phone onto the pad for a quick and easy power boost.
UNIVERSAL QI™ COMPATIBILITY
Power any Qi-compatible phone using this single charger. The BOOST?CHARGE Wireless Charging Pad 10W has been engineered to charge Apple and Samsung smartphones at the fastest possible speed while delivering 5 watts to all other Qi-enabled devices.
CASE COMPATIBLE UP TO 3MM
Charge without removing your case. Our BOOST?CHARGE Wireless Charging Pads are engineered to work with lightweight plastic cases up to 3mm.
LED LIGHT INDICATES SAFE AND SUCCESSFUL CHARGING
Foreign objects like keys and coins can disrupt your charge and even lead to wireless chargers emitting unnecessary power that can melt or damage your belongings. Charge with confidence as a white LED light indicates your phone is properly aligned and charging, while an amber light alerts you to the presence of a foreign object. The light is specially designed to not disrupt the surrounding environment.
Fast wireless charging made simple
Fast wireless charging up to 10 watts so you always safely get the fastest possible wireless charge. Just lay your phone onto the pad for a quick and easy power boost. -
Universal QI compatibility
Power any Qi-compatible phone using this single charger. The BOOST?CHARGE Wireless Charging Pad 10W has been engineered to charge Apple and Samsung smartphones at the fastest possible speed while delivering 5 watts to all other Qi-enabled devices. -
Case compatible up to 3mm
Charge without removing your case. The BOOST?CHARGE Wireless Charging Pads are engineered to work with lightweight plastic cases up to 3mm. -
LED light indicates safe and successful charging
Foreign objects like keys and coins can disrupt your charge and even lead to wireless chargers emitting unnecessary power that can melt or damage your belongings. Charge with confidence as a white LED light indicates your phone is properly aligned and charging, while an amber light alerts you to the presence of a foreign object. The light is specially designed to not disrupt the surrounding environment. -
Quick Charge 3.0 wall charger is included
The Quick Charge 3.0-compatible wall charger and cable ensure optimal charge to your wireless charger. You can also connect Quick Charge-compatible devices to the wall charger using the included cable to power up from zero to 80% in just 35 minutes.
- Belkin BoostCharge wireless charging pad - 10 Watt
- Product Type
- Wireless charging pad
- 1.33 cm
- Diameter
- 9 cm
- 74 g
- White
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Wireless Charging Standards
- Qi
- Power Provided
- 10 Watt
- Cables
- USB type A to micro-USB type B cable - 1.2 m
- 2-year warranty
- Product Type
- Designed For
- Mobile phone
- 1.33 cm
- Diameter
- 9 cm
- 74 g
- Enclosure Colour
- White
- Power Provided
- 10 Watt
- Wireless Charging
- Qi
- LED indicator, FOD (Foreign Object Detection), case compatible (plastic, up to 3 mm)
- Equipment Protection Value
- 2000 Euros
- Cables Included
- USB-IF, MFI, Qi
- Limited warranty - 2 years
