Belkin BOOST UP CHARGE 3-1 Wireless Charger (iPhone/Watch/AirPods) - Black
Quicklinx: G5SBWS00 Mfr#: WIZ001myBK
Type: Wireless Charger
Sorry but this product has been discontinued.
View used stock
Charge your iPhone, Apple Watch, and AirPods faster and all at once with the three-in-one charging dock. There's a 7.5W wireless charging pad for your iPhone, a magnetic charging module for your Apple Watch, and a 5W pad to wirelessly charge your AirPods. This stylish charging dock is perfect for your nightstand or home office.
  • Case compatible
    The 7.5W iPhone charging pad will charge through most lightweight cases, so you never need to remove your phone from its case to charge.
  • LED indicates charging status
    White light confirms active wireless charging. Amber light indicates an error with charging - this could be due to foreign object detection, misalignment, or other errors
  • Qi-compatible
    Qi is a wireless technology that uses inductive charging. The BOOST?CHARGE 3-in-1 wireless charger has been engineered to be Qi-compatible, allowing it to also charge phones, tablets, and other accessories with Qi technology.
Belkin BoostCharge 3-in-1 wireless charging stand - 7.5 Watt
Wireless charging stand
Wireless Charging
Wireless Charging Standards
Qi
Power Provided
7.5 Watt
3-year warranty
Mobile phone, smart watch, wireless earphones
Enclosure Colour
Power Provided
7.5 Watt
Wireless Charging
Qi
Case compatible (plastic, up to 3 mm)
Qi
Limited warranty - 3 years
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: G5SB 050901
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £22.39
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Belkin
Stock Status: Used Stock
Stock Status: Clearance
