Charge your iPhone, Apple Watch, and AirPods faster and all at once with the three-in-one charging dock. There's a 7.5W wireless charging pad for your iPhone, a magnetic charging module for your Apple Watch, and a 5W pad to wirelessly charge your AirPods. This stylish charging dock is perfect for your nightstand or home office.
Case compatible
The 7.5W iPhone charging pad will charge through most lightweight cases, so you never need to remove your phone from its case to charge. -
LED indicates charging status
White light confirms active wireless charging. Amber light indicates an error with charging - this could be due to foreign object detection, misalignment, or other errors -
Qi-compatible
Qi is a wireless technology that uses inductive charging. The BOOST?CHARGE 3-in-1 wireless charger has been engineered to be Qi-compatible, allowing it to also charge phones, tablets, and other accessories with Qi technology.
- Belkin BoostCharge 3-in-1 wireless charging stand - 7.5 Watt
- Product Type
- Wireless charging stand
- Black
- Wireless Charging
- Wireless Charging Standards
- Qi
- Power Provided
- 7.5 Watt
- 3-year warranty
- Product Type
- Designed For
- Mobile phone, smart watch, wireless earphones
- Enclosure Colour
- Black
- Power Provided
- 7.5 Watt
- Wireless Charging
- Qi
- Case compatible (plastic, up to 3 mm)
- Qi
- Limited warranty - 3 years
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
G5SB 050901 Condition: Customer return - item has been opened but is in excellent condition |
£30.11 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
