Our USB-C® Power Bank 20K has 20,000 mAh to provide up to an additional 9 hours of battery life to your MacBook, up to 28 hours to your iPad or up to 77 hours to your phone. Powerful enough to fully charge a USB-C laptop, it ensures your productivity remains uninterrupted. Convenient USB-A and USB-C ports keep devices charged without plugging into a wall outlet, so you can video conference for work or stream movies on long flights.
High power, travel ready
The USB-C Power Bank 20K has 20,000 mAh to provide additional hours of battery life to your MacBook, to your iPad and to your phone. Powerful enough to fully charge a USB-C laptop, it ensures your productivity remains uninterrupted. Convenient USB-A and USB-C ports keep devices charged without plugging into a wall outlet, so you can video conference for work or stream movies on long flights. -
Fast charge with 30W power delivery
With 30W USB-C Power Delivery, you can fully charge a MacBook without an outlet while on the go. Or, you can fast charge a compatible iPhone. With a USB-IF-certified cable included, you're ready to fast charge your device right away. -
Charging for 2
The USB-C and USB-A ports allow you to charge two devices at the same time. While one port charges your MacBook at up to 30W, the second port can charge a smaller device, such as a smartphone, at up to 12W.
- Belkin BoostCharge power bank - USB, 24 pin USB-C - 30 Watt
- Product Type
- Power bank
- Designed For
- Tablet, mobile phone
- 7.47 cm x 15.72 cm x 2.59 cm
- 517 g
- Black
- Output Connector Type
- Total 2: USB, 24 pin USB-C
- Fast Charge Technology
- Fast Charge, Power Delivery
- Battery
- 20000 mAh
- Power Provided
- 30 Watt
- Cables
- USB-C to USB-C cable
- 2-year warranty
- Product Type
- Power bank
- Designed For
- 7.47 cm
- 15.72 cm
- 2.59 cm
- 517 g
- Enclosure Colour
- Black
- Output connectors
- Total 2: 4 pin USB Type A, 24 pin USB-C
- Power Provided
- 30 Watt
- LED indicator
- Capacity
- 20000 mAh
- Equipment Protection Value
- 2500 US Dollars
- Cables Included
- USB-IF, MFI
- Limited warranty - 2 years
