Belkin BOOST CHARGE USB-A to USB-C Cable - Braided - 1m - White
Quicklinx: G5RQWS00 Mfr#: CAB002bt1MWH
Length: 1m
More than 50 In Stock
£5.88 ex VAT
£7.05 inc VAT
Keep your USB-C devices charged or easily sync music and photos from any USB-A port with durable USB-C to USB-A cables you can use just about anywhere. Made with enhanced braided nylon for added flexibility and strength, tested to withstand 10,000+ bends, and with USB-IF certification, you can count on worry-free performance.
You can find the perfect cable for any situation. Sync two devices across a room or connect your smartphone to a power bank in your pocket or backpack.
  • Charging cables that are built to last
  • Pick the length and color you need
Belkin BoostCharge - USB-C cable - 24 pin USB-C to USB - 1 m
USB-C cable
Sync and charge, braided
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
4 pin USB Type A - male
White
USB-C cable
Jacket Material
Nylon
Length
1 m
White
Connector
24 pin USB-C - male
USB-IF
Length: 1m
Brand: Belkin
