Keep your USB-C devices charged or easily sync music and photos from any USB-A port with durable USB-C to USB-A cables you can use just about anywhere. Made with enhanced braided nylon for added flexibility and strength, tested to withstand 10,000+ bends, and with USB-IF certification, you can count on worry-free performance.
You can find the perfect cable for any situation. Sync two devices across a room or connect your smartphone to a power bank in your pocket or backpack.
Charging cables that are built to last
Keep your USB-C devices charged or easily sync music and photos from any USB-A port with durable USB-C to USB-A cables you can use just about anywhere. Made with enhanced braided nylon for added flexibility and strength, tested to withstand 10,000+ bends, and with USB-IF certification, you can count on worry-free performance. -
Pick the length and color you need
- Belkin BOOST CHARGE - USB-C cable - 24 pin USB-C to USB - 1 m
- USB-C cable
- Sync and charge, braided
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 4 pin USB Type A - male
- Black
- 2-year warranty
- USB-C cable
- Jacket Material
- Nylon
- Length
- 1 m
- Black
- Connector
- USB-IF
- 2-year warranty
