Belkin BOOST CHARGE Micro-USB to USB-A Cable - Braided - 1m - Black
Quicklinx: G5RVWS00 Mfr#: CAB007bt1MBK
Length: 1m
£5.55 ex VAT
£6.66 inc VAT
Charge, sync, and connect your power bank, camera, or e-reader with a reliable cable that is perfect for home, car, or office. These cables are built with more strength and flexibility to use over and over again. This makes them ideal for easy placement in your bag to take on the go.
  • Efficient syncing and charging
    The Belkin BOOST CHARGE cable is designed to provide a seamless experience for syncing and charging your devices. Its robust design ensures that you can keep your devices powered up and synchronized with your content, making it an essential accessory for your digital lifestyle.
  • Durable construction
    Crafted with high-quality materials, this USB cable is built to withstand daily wear and tear. The sturdy connectors at both ends are designed for repeated use, ensuring a secure and reliable connection every time you plug in.
Belkin BoostCharge - USB cable - Micro-USB Type B to USB - 1 m
USB cable
Sync and charge
Length
1 m
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB cable
Sync and charge
Length
1 m
Connector
Length: 1m
Brand: Belkin
