Charge, sync, and connect your power bank, camera, or e-reader with a reliable cable that is perfect for home, car, or office. These cables are built with more strength and flexibility to use over and over again. This makes them ideal for easy placement in your bag to take on the go.
Efficient syncing and charging
The Belkin BOOST CHARGE cable is designed to provide a seamless experience for syncing and charging your devices. Its robust design ensures that you can keep your devices powered up and synchronized with your content, making it an essential accessory for your digital lifestyle. -
Durable construction
Crafted with high-quality materials, this USB cable is built to withstand daily wear and tear. The sturdy connectors at both ends are designed for repeated use, ensuring a secure and reliable connection every time you plug in.
- Belkin BoostCharge - USB cable - Micro-USB Type B to USB - 1 m
- USB cable
- Sync and charge
- Length
- 1 m
- Connector
- 5 pin Micro-USB Type B - male
- Connector (Second End)
- 4 pin USB Type A - male
- Black
- USB cable
- Sync and charge
- Length
- 1 m
- Black
- Connector
