Charge and sync your iPhone and iPad, or transfer music, photos, and data from any USB-A port with an MFi-certified connection. Enhanced braided nylon provides long-lasting durability as well as a premium look and feel to complement your devices. Testing to 10000+ bends assures longevity.
Durable design
The Belkin BOOST CHARGE Lightning cable features a braided nylon jacket that not only enhances its durability but also prevents tangling, ensuring a long-lasting and hassle-free charging experience. -
Efficient charging and syncing
Equipped with the ability to support both charging and syncing, this cable efficiently powers your device while simultaneously transferring data at high speeds, thanks to its Lightning / USB interface. -
Universal compatibility
Designed with a male Apple Lightning connector on one end and a male 4-pin USB Type-A connector on the other, this cable offers versatile connectivity options, making it compatible with a wide range of devices.
 - Belkin BoostCharge Lightning cable - Lightning / USB - 1 m
- Cable
 - Lightning cable - Lightning / USB
- Length
 - 1 m
 - White
- Connector
 - Lightning - male
- Connector (Second End)
 - USB - male
 - Sync and charge, braided
- Cable Type
 - Lightning cable
- Interface Supported
 - Lightning / USB
- Jacket Material
 - Nylon
- Length
 - 1 m
 - White
- Connector
 - Apple Lightning - male
 - 4 pin USB Type A - male
 - MFI
