Belkin 7.5W Wireless Charge Dock for Apple Watch and iPhone - White
Quicklinx: F9ZFWS00 Mfr#: F8J235MYWHT
Ideal for your nightstand, the BOOST UP Wireless Charging Dock provides 3-in-1 charging to power your essential devices while you sleep.
  • Fast wireless charging
    The wireless charging pad is optimized to recharge your phone battery as fast as possible. Your phone will charge faster using this dock.
  • Charge a third device
    A USB-A port allows you to connect a third device to create a charging station on your nightstand. This means all your essential devices can charge simultaneously to be fully charged when you need them.
  • No need to remove your case
    Charge without removing your phone from its case. The BOOST UP Wireless Charging Dock is engineered to work with lightweight plastic cases.
Belkin BOOST UP Wireless Charging Dock wireless charging stand - + AC power adapter - USB
Wireless charging stand + AC power adapter
18.6 cm x 10.1 cm x 12.6 cm
536 g
White
Output Connector Type
USB
Wireless Charging
Wireless Charging Standards
Qi
Power Device Details
AC power adapter - 4 pin USB Type A - 5 W - 1 A , AC power adapter: 2 x - wireless charging stand - 7.5 W
Cables
Power cable - 1.5 m
3-year warranty with product registration
Apple iPhone 8, 8 Plus, X, XR, XS, XS Max; Watch
Tablet, mobile phone, smart watch, headphones, power bank
18.6 cm
10.1 cm
12.6 cm
536 g
Enclosure Colour
White
Output connectors
4 pin USB Type A
AC power adapter: 4 pin USB Type A - 5 W - 1 A , AC power adapter: 2 x wireless charging stand - 7.5 W
Wireless Charging
Qi
AC Power Adapter Included
LED indicator, FOD (Foreign Object Detection), simultaneously charges up to 3 devices, Nightstand mode support, case compatible (plastic, up to 3 mm)
Equipment Protection Value
1500 British Pounds
Power cable - 1.5 m
Qi
Limited warranty - 3 years with product registration
Apple iPhone 8, 8 Plus, X, XR, XS, XS Max , Apple Watch
