The Belkin BSV603AF2M are surge strips that feature six (6) extra outlets for your DVD player, gaming console, speakers and other medium-sized appliances. Whenever voltage fluctuation or unexpected power surges occur, these inexpensive surge strips provide temporary power to your electronic devices – protecting them from permanent damage or data loss.
- Six (6) Outlet Surge Strip.
- 650 Joules of Surge protection.
- Two (2) Meter cord to place in any living space.
- Connected Equipment Warranty for Europe.
- Connected Equipment Warranty for UK.
Surge protection for up to six devices
Keep your electronic devices protected from dangerous power surges and spikes with the Belkin 6-Outlet Surge Protection Strip. Simply plug the surge protection strip into any AC wall outlet and connect up to six devices to keep them safe from power surges, lightning strikes, and AC contamination. Ideal for laptops, DVD players, gaming consoles, speakers, and other medium-sized electronics, the Belkin Surge Protection Strip is made with high-quality circuitry and premium absorptive materials to protect your devices and irreplaceable data. -
Protects against spikes and fluctuations
Connecting your electronic devices to the Belkin Surge Protection Strip protects them from unexpected power surges, such as short circuits and lightning strikes. The surge protection strip also keeps your devices safe from sudden voltage fluctuations or low-level spikes and drops that can damage or even destroy electronics over time. -
Surge protection up to 650 joules
This surge protection strip is rated to handle up to 650 joules and is designed to shield home-office and entertainment electronics against harmful voltage fluctuations, surges, and energy spikes. Oversize metal oxide varistors (MOVs) absorb excess electricity and release it as heat. Fiberglass MOV covers also help contain or smother fire if a large surge causes the MOVs to ignite. -
Protected outlets with recessed power switch
The Belkin Surge Protection Strip features high-quality construction and a durable design with damage-resistant housing that protects circuits from fire, impact, and rust. Six protected AC outlets make this surge protection strip an ideal solution for home offices, media rooms, and other areas where multiple devices need to be connected. A large recessed power switch helps ensure you never accidentally power off your connected devices and makes reboots easy, while sliding safety covers help protect children from harm. The Belkin Surge Protection Strip also includes a Not-Grounded Indicator that warns you when your outlet is not properly grounded. -
Heavy-duty 2-meter power cord
Protect your connected devices while keeping the Belkin Surge Protection Strip out of the way thanks to a 2-meter power cord. A heavy-duty design helps protect the cord from damage and ensures optimal power flow to your devices. -
Complete three-line AC protection
The Belkin Surge Protection Strip keeps connected devices safe with three-line AC protection. This type of protection guards against surges that occur between hot, neutral, and ground lines.
- Belkin 6 Outlet Power Surge Protector - surge protector
- Surge protector - external
- Output connectors
- 6 x power (surge)
- Power Output Connectors Details
- 6 x power (surge)
- Surge Suppression
- Surge Energy Rating
- 650 Joules
- Cables Included
- Power cable 2 m
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.17 |
