Power surges and lightning strikes are not the only things that can damage your home electronic equipment. Simply switching appliances on and off can create electrical imbalances that cause cumulative, permanent damage to your computers, peripherals and electronic equipment. Decades of research and power protection development have led Belkin to the release of this Economic Surge Protection series. Using advanced design elements and top-quality construction as well as superior circuitry, the E-Series offers complete protection from power surges, AC contamination and spikes. As the leading developer of surge protection solutions, Belkin engineers and rigorously tests all its products to ensure your equipment will be safe from harmful electrical imbalances. The Belkin E-Series is your economical solution for clean, safe power and the industry's best in construction, ratings and safety standards. Over 38 million Belkin Surge Protectors units are protecting consumer electronics worldwide.
- Belkin SurgeStrip E-Series - surge protector
- Surge protector - external
- Localisation
- English / United Kingdom
- Input Voltage
- AC 250 V
- Input Connectors
- 1 x power BS 1363
- Output connectors
- 6 x power BS 1363
- White
- Limited lifetime warranty
- White
- Localisation
- Input Voltage
- AC 250 V
- Frequency Required
- 50 Hz
- Input Connectors
- 1 x power BS 1363
- Power Output Connectors Details
- 6 x power BS 1363
- Max Electric Current
- 13 A
- Surge Suppression
- Surge Response Time
- 1 ns
- Surge Energy Rating
- 476 Joules
- Max Spike Voltage
- 6000 V
- Cables Included
- Power cable - integrated - 1 m
- Limited warranty - lifetime
Customer reviews
Write a review for the Belkin 6-Way Economy Surge Protector here!
Cable length...
Reviewed by Anonymous Review Posted 07/09/2006
This looks like a great value item (just bought one) but unfortunately I was caught out by the very short cable length and hence haven't tried it yet as it won't reach (just 1M cable only when I assumed it would be at least 2M or 3M as there is no mention of cable length in the description AFAICS?) so as long as you don't mind the very short cable length then I'd say this is a very good value purchase but if you need a longer cable (like me)then go with one of the more expensive surge protectors with a longer cable! :)
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
