Belkin 5W Wireless Charging Stand
Quicklinx: FCYDWS00 Mfr#: F7U070btBLK
Try wireless charging with the affordable BOOST?UP Wireless Charging Stand. 5W is perfect for charging throughout the day or an overnight power up. Qi certification provides peace of mind while universal compatibility makes it easy to find the charger that's right for your Qi-compatible phone or tablet. Say goodbye to low power anxiety. With this Qi-certified stand at your desk you are able to keep your smartphone accessible while charging up to 5W throughout the day. Staying charged all day is easier than ever. Keep a BOOST?UP Wireless Charging Stand on your nightstand and wake each morning fully charged.
  • Wireless charging within reach
  • Up to 5W charging power
  • Universal compatibility
    Take the guess work out of going wireless. The BOOST?UP Wireless Charging Stand is compatible with any device that uses Qi technology, including Apple, Samsung, Xperia, LG, Sony, Nokia, Google and more.
  • Compatible with lightweight cases
    Get a power boost without removing your phone's case. This wireless charger works with lightweight plastic cases up to 3mm.
  • Charging, confirmed
    A white LED light lets you know that your device is aligned properly and charging at up to 5W. An amber light indicates that there may be a foreign object, like a credit card, between your charging stand and device. When items come between the charger and your device, the charger could emit heat which may cause damage to your belongings. Foreign object detection is an important feature for any wireless charger, that's why it is included in all Belkin wireless chargers.
Belkin BOOST UP Wireless Charging Stand wireless charging stand - 5 Watt
Wireless charging stand
8 cm x 10.592 cm x 10.795 cm
Wireless Charging
Wireless Charging Standards
Qi
Power Provided
5 Watt
Mobile phone
8 cm
10.592 cm
10.795 cm
Enclosure Colour
Power Provided
5 Watt
Wireless Charging
Qi
LED indicator, FOD (Foreign Object Detection), temperature control
Qi
