Belkin 5W Wireless Charging Pad
Quicklinx: FCYCWS00 Mfr#: F7U068btBLK
The BOOST UP Wireless Charging Pad is an affordable solution for anybody interested in trying wireless charging. Qi certification provides peace of mind while universal compatibility makes it easy to find the charger that's right for your Qi-compatible phone. 5W is great for charging throughout the day or an overnight power up.
  • Effortless charging
    Experience the convenience of wireless charging with the Belkin BOOST UP Wireless Charging Pad. Designed specifically for cellular phones and tablets, this charging mat eliminates the need for cables, offering a clean and simple charging solution.
  • Safe power delivery
    Equipped with advanced safety features, the charging pad includes temperature control and an LED indicator to ensure your device charges safely and efficiently. The 5 W of power provided are optimized for your device's needs.
  • Universal compatibility
    Thanks to its compliance with Qi wireless charging standards, the Belkin BOOST UP Wireless Charging Pad is compatible with any Qi-enabled device, making it a versatile charging solution for a wide range of smartphones and tablets.
Belkin BOOST UP Wireless Charging Pad wireless charging mat - 5 Watt
Wireless charging mat
Wireless Charging
Wireless Charging Standards
Qi
Power Provided
5 Watt
Cables
Micro-USB to USB cable
Tablet, mobile phone
Enclosure Colour
Power Provided
5 Watt
Wireless Charging
Qi
LED indicator, temperature control
Qi
