Switch between 4 HDMI sources through one output cable. This high performance HDMI switch is compatible with Blu-ray, HD-DVD, STV, PS3, Xbox360 and so on. The switch can be changed with the included remote, manually or has a sensor that detects if just one source is active and sends data from that device to the HDTV.
- Belkin 4-Way HDMI Switchbox - video/audio switch - 4 ports
- Video/audio switch - 4 ports
- Subtype
- HDMI
- Ports
- 4 x HDMI
- Enclosure Type
- Desktop
- Subtype
- HDMI
- Ports
- 4 x HDMI
- Status Indicators
- Port status
- 4 x HDMI input , 1 x HDMI output
- Included Accessories
- Wireless remote control
