Experience next-level charging with advanced GaN technology. This addition to Belkin's charging family offers fast charging for your device in an exceptionally compact and convenient size. Foldable prongs make it as small as possible when not in use. Gallium nitride (GaN) is a high-performance alternative to the traditional silicon used in charging devices. GaN transistors produce less heat, allowing components to be closer together, which means you get a much smaller charger with all the power of a big one.
Fast charging with USB-C Power Delivery
For powering up at home or on the go, the 30W USB-C GaN Charger provides fast charging for USB-C PD-enabled devices. Charge a MacBook Air from 0 to 50% in just 70 minutes or fast charge an iPhone 8 or later from 0 to 50% in 30 minutes. -
Safe and reliable power
Built-in protection keeps your devices safe from overcurrent and overvoltage damage. USB-C Power Delivery certification ensures reliable performance with all compatible devices. -
Charge your USB-C devices
The wall charger supports a wide range of USB-C devices, including those from Samsung and Google as well as MacBook Air, iPad Pro, and iPhone 8 and later models.
- Belkin BoostCharge Wall Charger power adapter - 24 pin USB-C - 30 Watt
- Product Type
- Power adapter
- 3.9 cm x 3.975 cm x 4 cm
- White
- Output Connector Type
- 24 pin USB-C
- Fast Charge Technology
- Fast Charge, Power Delivery
- Power Provided
- 30 Watt
- 2-year warranty
- Product Type
- Power adapter
- Designed For
- Tablet, mobile phone, notebook
- 3.9 cm
- 3.975 cm
- 4 cm
- Enclosure Colour
- White
- Output connectors
- 24 pin USB-C
- Power Provided
- 30 Watt
- Over voltage protection, retractable plug, overcurrent protection, GaN Technology
- Equipment Protection Value
- 2500 US Dollars
- Limited warranty - 2 years
