Belkin 20K Power Bank USB-A & C 15W Black
Quicklinx: GWSPWS00 Mfr#: BPB012BTBK
Device Type: Power Bank USB-A & C 15W Black
Type: Power Bank
Product Range: Belkin BoostCharge
Product Model: PowerBank 8000
More than 50 In Stock
£23.96 ex VAT
£28.75 inc VAT
Charge up to 3 devices at the same time with Belkin compact and powerful Power Bank 20K. It has 2 USB-A ports and 1 USB-C port, delivering a total of up to 15W when using all 3 ports.
  • Power 3 devices
    Plug into portable power for up to three devices at the same time with its USB-C port and 2 USB-A ports.
  • Cable included
    Start charging immediately. Belkin Power Bank comes with a USB-A to USB-C cable so you can start charging right out of the box.
  • LED indicator light
    LED battery indicator lights let you know when it's time to charge or when you're good to go.
Belkin BoostCharge power bank - 2 x USB, 24 pin USB-C - 15 Watt
Power bank
2.1 cm x 15.3 cm x 7.6 cm
426 g
Output Connector Type
Total 3: 2 x USB, 24 pin USB-C - on cable: USB, USB-C
20000 mAh
Power Provided
15 Watt
Cables
USB-C to USB-A cable - 15.2 cm
Power bank
Tablet, mobile phone
2.1 cm
15.3 cm
7.6 cm
426 g
Enclosure Colour
Output connectors
Total 3: 2 x 4 pin USB Type A, 24 pin USB-C
Power Provided
15 Watt
Detachable Cable Connector Type
USB Type A, USB-C
LED indicator
20000 mAh
Equipment Protection Value
1500 British Pounds
Type: Power Bank
Brand: Belkin
