This compact 18-watt wall charger with USB-Power Delivery means fast charging for your USB-PD-enabled devices. Supports Fast Charge for iPhone to charge iPhone 8 or later from zero to 50% in 30 minutes with the included cable, and other smartphones/ tablets at optimal speeds. Purposefully designed to be travel-friendly, this pocket-sized charger easily fits to any environment at home or when you're out and about. A connected equipment warranty protects your devices for added peace of mind.
With 18W and USB-Power Delivery on board, this charger supports Fast Charge to charge your iPhone battery from 0-50% in only 30 minutes, and other compatible devices at optimal speeds. -
Seriously small
This compact charger sits flat to the wall to fit easily behind furniture or in hard-to-reach outlets. It's also perfectly-sized to fit in a pocket or bag, which means you'll have access to fast charging wherever you're headed. -
Included MFi-Certified cable
The cable is also MFi-certified to guarantee compatibility with iOS devices, and meets the high-quality standards set by Apple.
- Belkin BoostCharge Wall Charger power adapter - 24 pin USB-C - 18 Watt
- Product Type
- Power adapter
- 5 cm x 4.875 cm x 5.23 cm
- Localisation
- United Kingdom
- Output Connector Type
- 24 pin USB-C - on cable: Lightning
- Max Electric Current
- 3.6 A
- Fast Charge Technology
- Fast Charge
- Power Provided
- 18 Watt
- Cables
- USB-C to Lightning cable - 1.2 m
- 2-year warranty
- Product Type
- Power adapter
- Designed For
- Tablet, mobile phone
- 5 cm
- 4.875 cm
- 5.23 cm
- Localisation
- United Kingdom
- Output connectors
- 24 pin USB-C
- Power Provided
- 18 Watt
- Detachable Cable Connector Type
- Lightning
- 3.6 A
- Fast Charge
- Equipment Protection Value
- 1500 British Pounds
- Cables Included
- USB-IF, MFI
- Limited warranty - 2 years
