Safe, fast wireless charging. Designed for any orientation, it's perfect for charging while scrolling the Internet or streaming videos.
Charge in portrait and landscape mode
This original and thoughtful design makes it easy to align your device for a fast wireless charge in landscape or portrait mode. From browsing the web to watching a movie, it's easy to keep using your phone while charging. -
Universal compatibility
The BOOST CHARGE wireless charging stand has been engineered to be compatible with your device. -
Case compatible
Charge without removing your case. Just place your phone onto the stand and keep chatting, browsing, or scrolling. -
LED light indicates safe and successful charging
Foreign objects between your phone and charger can disrupt your charge and even lead to wireless chargers emitting unnecessary power that can melt or damage your belongings. Charge with confidence as an LED light indicates your phone is properly aligned and charging.
- Belkin BoostCharge wireless charging stand - + AC power adapter - 10 Watt
- Product Type
- Wireless charging stand + AC power adapter
- 10 cm x 10 cm x 11 cm
- 110 g
- Black
- Fast Charge Technology
- Qualcomm Quick Charge 3.0
- Wireless Charging
- Wireless Charging Standards
- Qi
- Power Provided
- 10 Watt
- Cables
- Micro-USB cable - 1.2 m
- 2-year warranty
- Product Type
- Designed For
- Mobile phone
- 10 cm
- 10 cm
- 11 cm
- 110 g
- Enclosure Colour
- Black
- Power Provided
- 10 Watt
- Wireless Charging
- Qi
- AC Power Adapter Included
- LED indicator, portrait/landscape orientation, case compatible (plastic, up to 3 mm)
- Cables Included
- Qi
- Limited warranty - 2 years
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
G5RN 050721 Condition: Damaged stock - Item is new but has packaging damage |
£10.74 |
Ref:
G5RN 050433 Condition: Customer return - item has been used and shows signs of use |
£5.71 |
Ref:
G5RN 050434 Condition: Damaged stock - Item is new but has packaging damage |
£6.12 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
