Belkin 10W Wireless Charging Stand with PSU, Micro USB Cable - Black
Quicklinx: G5RNWS00 Mfr#: WIB001myBK
Safe, fast wireless charging. Designed for any orientation, it's perfect for charging while scrolling the Internet or streaming videos.
  • Charge in portrait and landscape mode
    This original and thoughtful design makes it easy to align your device for a fast wireless charge in landscape or portrait mode. From browsing the web to watching a movie, it's easy to keep using your phone while charging.
  • Universal compatibility
    The BOOST CHARGE wireless charging stand has been engineered to be compatible with your device.
  • Case compatible
    Charge without removing your case. Just place your phone onto the stand and keep chatting, browsing, or scrolling.
  • LED light indicates safe and successful charging
    Foreign objects between your phone and charger can disrupt your charge and even lead to wireless chargers emitting unnecessary power that can melt or damage your belongings. Charge with confidence as an LED light indicates your phone is properly aligned and charging.
Belkin BoostCharge wireless charging stand - + AC power adapter - 10 Watt
Wireless charging stand + AC power adapter
10 cm x 10 cm x 11 cm
110 g
Fast Charge Technology
Qualcomm Quick Charge 3.0
Wireless Charging
Wireless Charging Standards
Qi
Power Provided
10 Watt
Cables
Micro-USB cable - 1.2 m
Mobile phone
10 cm
10 cm
11 cm
110 g
Enclosure Colour
Power Provided
10 Watt
Wireless Charging
Qi
AC Power Adapter Included
LED indicator, portrait/landscape orientation, case compatible (plastic, up to 3 mm)
Qi
