Compact and convenient, the 10-port USB charging station provides optimal charging for any combination of smartphones, tablets or other mobile devices. Intelligent power delivery detects the necessary power to charge each device quickly and safely, even when all ten ports are in use. The charging station also provides essential multi-port surge protection to safeguard connected devices from damage.
Reliable multi-port charging
120-watt external power supply ensures that up to 2.4 amps is delivered to each port. This provides optimal charging for each connected device for consistent charge time, regardless of the number and size of devices connected. -
Compact convenience
With ten universal USB-A ports available, the hub allows simultaneous, multiple device charging, all from a single outlet. Since the power supply unit is external, the small, compact hub fits easily onto a desktop, or can be wall-mounted to save space. -
Intelligent charging
Able to automatically detect each connected device, the hub delivers the precise amount of power up to 2.4A for optimal charging. Included surge protection simultaneously safeguards each device from too much power.
- Belkin ROCKSTAR charging station - 10 x 4 pin USB Type A - 120 Watt
- Product Type
- Charging station
- Designed For
- Tablet, mobile phone
- 8.89 cm x 3.18 cm x 17.02 cm
- Output Connector Type
- Total 10: 10 x 4 pin USB Type A
- Power Provided
- 120 Watt
- Power Device Details
- 10 x - 4 pin USB Type A - 2.4 A
- Product Type
- Charging station
- Designed For
- 8.89 cm
- 3.18 cm
- 17.02 cm
- Output connectors
- Power Provided
- 120 Watt
- 10 x 4 pin USB Type A - 2.4 A
- Wall mountable, surge protection, anti-slip base, desk mountable
- Equipment Protection Value
- 4000 Euros
