Belkin 10-Port 2.4A USB Charger - includes EU & UK plugs
Quicklinx: D3YVWS00 Mfr#: B2B139vf
Type: Charger
Hurry, only 3 left in stock!
£80.91 ex VAT
£97.09 inc VAT
Compact and convenient, the 10-port USB charging station provides optimal charging for any combination of smartphones, tablets or other mobile devices. Intelligent power delivery detects the necessary power to charge each device quickly and safely, even when all ten ports are in use. The charging station also provides essential multi-port surge protection to safeguard connected devices from damage.
  • Reliable multi-port charging
    120-watt external power supply ensures that up to 2.4 amps is delivered to each port. This provides optimal charging for each connected device for consistent charge time, regardless of the number and size of devices connected.
  • Compact convenience
    With ten universal USB-A ports available, the hub allows simultaneous, multiple device charging, all from a single outlet. Since the power supply unit is external, the small, compact hub fits easily onto a desktop, or can be wall-mounted to save space.
  • Intelligent charging
    Able to automatically detect each connected device, the hub delivers the precise amount of power up to 2.4A for optimal charging. Included surge protection simultaneously safeguards each device from too much power.
Belkin ROCKSTAR charging station
Charging station
8.89 cm x 3.18 cm x 17.02 cm
Output Connector Type
10 x 4 pin USB Type A
Power Device Details
10 x - 4 pin USB Type A - 2.4 A
Charging station
8.89 cm
3.18 cm
17.02 cm
Output connectors
Total 10: 10 x 4 pin USB Type A
Power Provided
120 Watt
10 x 4 pin USB Type A - 2.4 A
Wall mountable, surge protection, anti-slip base, desk mountable
Equipment Protection Value
4000 Euros
Type: Charger
Brand: Belkin
Price Range Ex VAT: 50 - 100
