Belkin 1.2m Lightning to USB Braided Tangle Free Cable - Gold
Quicklinx: 9S4QWS00 Mfr#: F8J144BT04-GLD
Charge and sync all your Lightning connector devices quickly and safely, using just one cable. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road.
  • Quickly charge and sync your devices
  • Compact & portable
    The Lightning to USB cable can reach the perfect distance while still being compact enough to toss in a bag and go. It plugs into any USB 2.0 port. Connect to your laptop to charge and sync, use your own wall charger to charge from the wall, or plug into a car charger and charge on the road.
Belkin MIXIT Metallic Lightning to USB Cable - Lightning cable - Lightning / USB 2.0 - 1.2 m
Cable
Length
1.2 m
Gold
Connector
USB - male
Connector (Second End)
Lightning - male
Sync and charge
Cable Type
Lightning cable
Interface Supported
Lightning / USB 2.0
Shielding Material
Aluminium braid
Length
1.2 m
Sync and charge
Gold
Connector
4 pin USB Type A - male
Apple Lightning - male
MFI
