Product
BeatsX Wireless Earphones - White
Clearance!
Clearance
Quicklinx: CCK2WS00 Mfr#: MLYF2ZM/A
Colours:
Fit for your life, BeatsX earphones are the perfect wireless companion. With up to 8 hours of battery life and Fast Fuel technology, you can experience authentic, clear sound throughout your day.
Apple W1 Chip
Beats and Apple are changing the way you listen to music with the introduction of Apple W1 technology in BeatsX . Incorporating the incredible W1 chip brings seamless setup and switching for your Apple devices, amazing battery life, and 5-minute Fast Fuel charging.
Requires iCloud account and macOS Sierra, iOS 10, or watchOS 3.
5 Minutes of Charge = 2 Hours of Playback
With Fast Fuel, 5 minutes of charging gets you 2 hours of playback when battery is low.
Take Calls With RemoteTalk
With Siri-compatible RemoteTalk, you can take calls with an on-cable mic and play music with easy-to-use controls, seamlessly switching back and forth as you go about your day.
Flex-Form Cable
The unique Flex-Form cable provides a flexible fit for all-day wear, while a variety of eartip and secure-fit wingtip options offer further personalized comfort and stability.
Authentic, Clear Acoustics
From listening to music to taking calls, clear acoustics deliver an authentic listening experience, no matter where your day takes you.
Up To 8 Hours Of Battery Life
Beatsx features an 8-hour battery powered by the Apple W1 chip so it is ready when you are. Whether on the go or at work, you can enjoy wireless listening throughout your day.
What's in the box?
  • BeatsX earphones
  • Eartips with four size options
  • Removable secure-fit wingtips
  • Pocket-sized carrying case
  • Lightning to USB-C charging cable
  • Quick Start Guide
  • Warranty Card
  • Wireless the way it should be
    Beats X works as hard as you do. Sleek, light and compact, these earphones are your perfect wireless companion. With Bluetooth technology, Beats X goes wherever you go with great wireless efficiency.
  • Sound that stays with you
    Beats X features authentic, clear sound with optimized noise isolation for an immersive listening experience. An innovative acoustic design delivers a clean treble response and distortion-free bass for a natural tonality across a broad range of genres.
  • Fit for your life
    BeatsX is incredibly sleek and comfortable for all-day wear. The flex-form cable provides a flexible fit, a variety of earbuds provide personalized comfort, and secure-fit wingtips offer added stability.
Beats X - earphones with mic
Earphones - Bluetooth - wireless
Compatibility
iPhone, iPad, iPod
Recommended Use
Portable electronics
White
Headphones Form Factor
In-ear - over-the-ear mount
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Noise Isolating
Noise isolating
Microphone
On-cable
Microphone Operation Mode
Mono
Controls
Volume, answer/end
1 year warranty
10.5-inch iPad Pro; 12.9-inch iPad Pro (1st generation, 2nd generation, 3rd generation); 9.7-inch iPad (5th generation, 6th generation); 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini 2; 3; 4; iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, X; iPod touch (6G); TV; Watch
Compatibility
iPhone, iPad, iPod
White
Recommended Use
Headphones
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Noise Isolating
In-Cord Volume Control
Microphone
On-cable
Mono
Remote Control
Controls
Volume, answer/end
USB charge cable
Carrying case, 4 ear tips, removable secure fit wingtips
Headphone battery rechargeable - Lithium Ion
Run Time (Up To)
8 hour(s)
Limited warranty - 1 year
Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation, 3rd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, X , Apple iPod touch (6G) , Apple TV , Apple Watch
