Fit for your life, Beatsx earphones are the perfect wireless companion. With up to 8 hours of battery life and Fast Fuel technology, you can experience authentic, clear sound throughout your day.
Apple W1 Chip
Beats and Apple are changing the way you listen to music with the introduction of Apple W1 technology in BeatsX . Incorporating the incredible W1 chip brings seamless setup and switching for your Apple devices, amazing battery life, and 5-minute Fast Fuel charging.
Requires iCloud account and macOS Sierra, iOS 10, or watchOS 3.
5 Minutes of Charge = 2 Hours of Playback
With Fast Fuel, 5 minutes of charging gets you 2 hours of playback when battery is low.
Take Calls With RemoteTalk
With Siri-compatible RemoteTalk, you can take calls with an on-cable mic and play music with easy-to-use controls, seamlessly switching back and forth as you go about your day.
Flex-Form Cable
The unique Flex-Form cable provides a flexible fit for all-day wear, while a variety of eartip and secure-fit wingtip options offer further personalized comfort and stability.
Authentic, Clear Acoustics
From listening to music to taking calls, clear acoustics deliver an authentic listening experience, no matter where your day takes you.
Up To 8 Hours Of Battery Life
Beatsx features an 8-hour battery powered by the Apple W1 chip so it is ready when you are. Whether on the go or at work, you can enjoy wireless listening throughout your day.
What's in the box?
- BeatsX earphones
- Eartips with four size options
- Removable secure-fit wingtips
- Pocket-sized carrying case
- Lightning to USB-C charging cable
- Quick Start Guide
- Warranty Card
Wireless the way it should be
Beats X works as hard as you do. Sleek, light and compact, these earphones are your perfect wireless companion. With Bluetooth technology, Beats X goes wherever you go with great wireless efficiency. -
Sound that stays with you
Beats X features authentic, clear sound with optimized noise isolation for an immersive listening experience. An innovative acoustic design delivers a clean treble response and distortion-free bass for a natural tonality across a broad range of genres. -
Fit for your life
BeatsX is incredibly sleek and comfortable for all-day wear. The flex-form cable provides a flexible fit, a variety of earbuds provide personalized comfort, and secure-fit wingtips offer added stability.
- Beats X - earphones with mic
- Product Type
- Earphones - Bluetooth - wireless
- Compatibility
- iPhone, iPad, iPod
- Recommended Use
- Portable electronics
- Black
- Headphones Form Factor
- In-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Sound Output Mode
- Stereo
- Noise Isolating
- Microphone
- On-cable
- Microphone Operation Mode
- Mono
- Controls
- Volume, answer/end
- 1-year warranty
- Designed For
- TV 4K, HD
- Product Type
- Compatibility
- Black
- Recommended Use
Audio Output
- In-ear
- Wireless
- Bluetooth
- Sound Output Mode
- Stereo
- Noise Isolating
- In-Cord Volume Control
Microphone
- On-cable
- Mono
Remote Control
- Controls
- Included Accessories
- Carrying case, 4 ear tips, removable secure fit wingtips
- Cable Details
- USB charge cable
- Battery
- Headphone battery rechargeable - Lithium Ion
- Run Time (Up To)
- 8 hour(s)
- Limited warranty - 1 year
- Designed For
- Apple TV 4K, HD
