Beats X Earphones - Satin Silver
Quicklinx: DTMKWS00 Mfr#: MTH62ZM/A
Fit for your life, Beats X earphones are the perfect wireless companion. Experience authentic, clear sound throughout your day with a long battery life. Their unique flex-form cable provides all-day comfort and easy pocket portability.
  • Driven by the Apple W1 chip
    Incorporating the efficient Apple W1 chip brings seamless setup and switching for your Apple devices, up to 8 hours of battery life and Fast Fuel technology for 2 hours of play with a 5-minute charge.
  • Wireless the way it should be
    BeatsX works as hard as you do. Sleek, light and compact, these earphones are your perfect wireless companion. They instantly set up — just power on and hold near your iPhone — then simultaneously connect to your Apple Watch, iPad and Mac.
  • Stay connected, stay in the zone
    RemoteTalk allows you to take calls with a built-in mic, play music, adjust volume and activate Siri. The Apple W1 chip features Class 1 Bluetooth connectivity — the advanced classification for range and signal strength. With excellent performance, BeatsX seamlessly syncs to your devices, so you can easily move about, keep the music going and stay productive throughout your day.
  • Sound that stays with you
    BeatsX features authentic, clear sound with optimized noise isolation for an immersive listening experience. An innovative acoustic design delivers a clean treble response and distortion-free bass for the most natural tonality across a broad range of genres.
  • Fit for your life
    Whether playing in your ears or hanging around your neck, BeatsX is incredibly sleek and comfortable for all-day wear. The unique Flex-Form cable provides a flexible fit, while a variety of eartip options offer personalized comfort. And when you’re not wearing your earphones, magnetic earbuds keep them tangle-free, and they easily coil up for compact portability.
Beats X - earphones with mic
Earphones - Bluetooth - wireless
Compatibility
iPhone, iPad, iPod
Recommended Use
Portable electronics
Satin silver
Headphones Form Factor
In-ear
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Noise Isolating
Noise isolating
Microphone
On-cable
Microphone Operation Mode
Mono
Controls
Volume, answer/end
1-year warranty
10.5-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad (5th generation, 6th generation); 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini 2; 3; 4; iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), X, XR, XS, XS Max; iPod touch; TV; Watch
Compatibility
iPhone, iPad, iPod
Satin silver
Recommended Use
Headphones
In-ear
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Noise Isolating
In-Cord Volume Control
Microphone
On-cable
Mono
Remote Control
Controls
Volume, answer/end
Carrying case, 4 ear tips, removable secure fit wingtips
Cable Details
USB charge cable
Headphone battery rechargeable - Lithium Ion
Run Time (Up To)
8 hour(s)
Limited warranty - 1 year
Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation, 3rd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), X, XR, XS, XS Max , Apple iPod touch , Apple TV , Apple Watch
