Beats Studio Buds - Black
Quicklinx: HJ1GWS00 Mfr#: MJ4X3ZM/A
Connectivity: Wireless
Colour: Black
£50.83 ex VAT
£60.99 inc VAT
Beats was born to deliver music as the artist intended. Beats Studio Buds are engineered to deliver powerful, balanced sound in a compact design, through an entirely customized acoustic platform. A proprietary, dual-element diaphragm driver resides within a two-chamber housing, resulting in clear sound with outstanding stereo separation. An advanced digital processor then optimizes audio performance for loudness and clarity, while simultaneously ensuring clean noise-cancellation. The result - immersive sound that pulls the emotion of music from the studio to your ears to keep you going all day long.
  • Control the noise
    With two distinct listening modes, you are in total control of your sound. Active Noise Cancelling (ANC) continuously blocks unwanted outside noise using a finely-tuned filter that dynamically adapts to your surroundings. When you need to hear the world around you, switch to Transparency mode at the press of a button. The external-facing microphones mix the sounds of your surroundings back in with your music for a natural, 'open' listening experience.
  • Power your day
    The earbuds have up to 8 hours of listening time with two additional charges provided by its pocket-sized charging case. That means that Beats Studio Buds give you up to 24 hours of combined playback. With ANC or Transparency mode turned on, you'll get up to 5 hours of listening time, 15 combined with the case. If you need a little extra juice, 5-minute Fast Fuel charging gives up to 1 hour of playback when battery is low. Now that's wireless freedom.
  • Choose your fit
    Three soft, silicone eartip sizes (small, medium, or large) give you a customized fit and create an acoustic seal for an even more immersive listening experience. These size options provide comfort, stability, and the confidence of staying put. Beats Studio Buds were made to fit seamlessly into your life with its sleek, compact in-ear design. Its matching charging case offers superior portability with a rounded, slim design that easily fits in your pocket or purse. Even better, the earbuds themselves offer an IPX4 rating for sweat and water resistance.
  • Keep the connection
    With Class 1 Bluetooth technology, Beats Studio Buds offer extended wireless range and fewer dropouts. Dual-beam forming microphones target your voice and filter out wind and external noise for high-quality call performance and elevated voice clarity. On-ear controls allow you to manage calls and control music. You'll also be able to customize the "Press and Hold" function to work for either ANC or your voice assistant.
  • Compatible with Apple and Android
    Beats Studio Buds feature simple one-touch pairing for Apple and Android devices and easily connect via Bluetooth. With the Beats app for Android, you'll get features like built-in controls, device status (i.e. battery levels), and firmware updates. With Apple devices, those features are built in to iOS with no app required, and you can also activate Siri hands-free just by saying "Hey Siri". And the USB-C charge connector provides a single charging solution across both Apple and Android platforms.
Beats Studio Buds - true wireless earphones with mic
True wireless earphones - Bluetooth
Compatibility
iPhone, iPad, iPod, Mac
Recommended Use
Portable electronics
Additional Functions
Transparency mode
Headphones Form Factor
In-ear
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Active Noise Canceling
Controls
Voice assistant, ANC on/off
Intelligent Assistant
Siri
True wireless earphones - Bluetooth - wireless
Compatibility
Transparency mode
Dimensions & Weight Details
Charging case: 5.1 cm x 7.2 cm x 2.55 cm / 48 g
1.85 cm
2.05 cm
1.5 cm
5 g
Recommended Use
Protection
Sweat-resistant, IPX4, water-resistant
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Fast Fuel technology
Microphone
Built-in
Remote Control
Controls
Internet of Things (IoT)
Siri
3 pairs of silicone ear tips, charging case, logo sticker, USB-C to USB-C charging cable
Bluetooth Class 1
Headphone battery rechargeable - Lithium Ion
Run Time (Up To)
8 hour(s)
Run Time Details
Continuous playback (with included charging case): up to 24 hours , Continuous playback (noise cancelling ON): up to 5 hours , Continuous playback (noise cancelling ON / with included charging case): up to 15 hours
Colour: Black
Brand: Beats
Stock Status: While stocks last
Stock Status: Clearance
