Beats Solo2 headphones offer improved acoustics, a wider range of sound, and enhanced clarity for all the music on your iPhone, iPad, or iPod. They also deliver even greater comfort thanks to a streamlined, lightweight, and durable design.
Feel your music
The Beats Acoustic Engine makes your listening experience personal and real. The signature DSP software is designed to generate the emotional experience that some of the music industry's greatest rock, hip-hop, pop, electronic, and R&B producers want you to feel. This is how music would sound if the artist could play it back for you in person. -
Put the world on mute
Silence the noise from your daily commute or the drama from your loud neighbors with dual-mode Adaptive Noise Canceling. When you're listening to music, ANC automatically strikes the perfect blend between your music and the world outside. If you only want to use the headphone to cancel external noise, the ANC only mode automatically increases the level of noise cancelation, to put the world on mute. -
Built-in rechargeable battery
Dead batteries can kill your vibe. The Beats Studio Wireless comes with a built-in rechargeable battery that lasts 12 hours when using wirelessly and 20 hours when you do decide to plug in. To prevent wasting energy, the Auto On/Off feature turns the headphone off when you unplug from a wired connection and with the Battery Fuel Gauge, you always know how much juice is left. Forget specialized adapters; the Studio Wireless can be charged via micro USB almost anywhere. -
Lighter, stronger, and more comfortable
When Beats Studio reimagined the iconic Studio, Beats Studio designed it like a beautiful sports car and made disciplined choices. It is streamlined with fast curves, smooth surfaces, and no visible screws. Beats Studio reduced the original weight and gave it a lighter, stronger, and more comfortable headband. The softer ear cups have an ergonomic bellow that creates a flexible custom fit, so you can keep your music all to yourself.
- Beats Studio Wireless - headphones with mic
- Product Type
- Headphones - Bluetooth - wireless
- Compatibility
- iPhone, iPad, iPod
- Recommended Use
- Portable electronics
- Gloss black
- Headphones Form Factor
- Full size
- Foldable
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Active Noise Canceling
- Microphone
- On-cable
- Controls
- Volume, answer/end, play/pause, next/previous track
- Product Type
- Compatibility
- Gloss black
- Recommended Use
- Max Operating Distance
- 9 m
Audio Output
- Full size
- Foldable
- Wireless
- Bluetooth
- Sound Output Mode
- Stereo
- Active Noise Cancelling Technology
- Adaptive Noise Cancelling
- 20 - 20000 Hz
Microphone
- On-cable
Remote Control
- Controls
Wireless Link
- Transmission Range
- 9 m
- Connector Type
- Headphones (mini-phone stereo 3.5 mm 4-pole)
Cable
- Detachable Cable
- Included Accessories
- Hard case, cleaning cloth
- Cable Details
- Headphones cable , USB charge cable
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 20 hour(s)
