A complete update of Beats' most popular model, the Beats by Dr. Dre Solo2 headphones offer improved acoustics, a wider range of sound, and enhanced clarity for all the music on your iPhone, iPad, or iPod. They also deliver even greater comfort thanks to a streamlined, lightweight, and durable design.
Feel a new kind of sound
The Solo2 headphones have a more dynamic and wider range of sound, with a clarity that can bring you closer to what the artist intended you to hear. You'll feel the higher fidelity audio no matter what type of music you play. -
Custom comfort
Starting at the center of the flexible headband, the frame is curved even more to enhance the custom-fit feeling. The earcups are ergonomically angled to complete this natural fit, and they pivot for optimal comfort and sound delivery. The earcups' premium material also helps dissipate heat and minimize sound leakage. -
Streamlined design
Fast-flowing curves, a lack of visible screws, and easy foldability exemplify the sleek aesthetic of Beats Solo2. That thoughtful approach extends to engineering and material selection, which together resulted in a more durable headphone that stands up to extended use.
- Beats by Dr. Dre Solo2 - headphones with mic
- Product Type
- Headphones - Bluetooth - wireless
- Compatibility
- iPhone, iPad, iPod
- Recommended Use
- Portable electronics
- Blue
- Headphones Form Factor
- On-ear
- Foldable
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Sound Output Mode
- Stereo
- Microphone
- On-cable
- Controls
- Volume
- 1-year warranty
- Product Type
- Compatibility
- 215 g
- Blue
- Recommended Use
Audio Output
- On-ear
- Foldable
- Wireless
- Bluetooth
- Sound Output Mode
- Stereo
- In-Cord Volume Control
Microphone
- On-cable
Remote Control
- Controls
- Volume
- Connector Type
- Headphones (mini-phone stereo 3.5 mm) , USB 2.0
- Included Accessories
- Carrying case
- Cable Details
- Microphone cable , USB charge cable
- Battery
- Headphone battery rechargeable - Lithium Ion
- Run Time (Up To)
- 12 hour(s)
- Limited warranty - 1 year
