Get inspired with Solo Pro wireless headphones. To deliver sound how you want it, Solo Pro features two listening modes: Active Noise Canceling (ANC) and Transparency. Beats' Pure ANC gives you the space to create with fully immersive sound, while Transparency helps you stay aware of your surroundings. Every detail of Solo Pro has been carefully considered, right down to the intuitive way the headphones turn on and off via folding. The ergonomic design delivers exceptional comfort for extended wear and sleek style.
Control your sound
Solo Pro boasts an advanced acoustic platform with powerful, emotive sound and balanced tonality. With two distinct listening modes, you can choose whether you want to turn the world off - or on. Beats' Pure ANC actively blocks external noise and uses real-time audio calibration to preserve clarity, range, and emotion, giving you the space you need to create and stay inspired. It continuously pinpoints external sounds to block while automatically responding to individual fit in real time, optimizing sound output to deliver a premium listening experience. -
Style meets comfort
The design process focused on ergonomics to ensure a comfortable fit for extended use. The brushed metal side arms are adjustable with enhanced durability, while the controls are seamlessly blended into the ear cups for easy use with a clean, stylish finish. -
Stay connected
With Class 1 Bluetooth technology, these wireless headphones offer extended range and fewer dropouts, so they stay connected no matter where your day takes you. A speech-detecting accelerometer and dual-beam forming microphones target your voice and filter out external noise for exceptional call performance. The seamlessly integrated on-ear controls let you take calls, skip songs, and control volume directly from the ear cup. -
Listen together
Audio Sharing lets you wirelessly share audio between Solo Pro and any other pair of Beats headphones or AirPods. From a song, to a podcast, or even a movie - some things are better together. Now you can easily share whatever you're listening to on an iPhone or iPad and each control your own volume. Simply bring the second set of headphones near your Apple device and connect with a tap. All that's left to do is listen - together.
- Beats Solo Pro - headphones with mic
- Product Type
- Headphones - Bluetooth - wireless
- Compatibility
- iPhone, iPad, iPod, Mac
- Recommended Use
- Portable electronics
- Additional Functions
- Transparency mode
- Black
- Headphones Form Factor
- On-ear
- Foldable
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 4.0
- Sound Output Mode
- Stereo
- Active Noise Canceling
- Controls
- Volume, answer/end, play/pause, next/previous track
- Intelligent Assistant
- Siri
- Product Type
- Compatibility
- Transparency mode
- 17.9 cm
- 267 g
- Black
- Body Material
- Brushed metal
- Recommended Use
Audio Output
- On-ear
- Foldable
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.0
- Sound Output Mode
- Stereo
- Active Noise Cancelling Technology
- Pure Adaptive Noise Cancelling
- Adjustable Headband
- Fast Fuel technology, Apple H1 chip
Microphone
- Form Factor
- Built-in
Remote Control
- Controls
Internet of Things (IoT)
- Siri
- Included Accessories
- Carrying case, Lightning to USB cable
- Cable Details
- Lightning to USB cable - detachable
- Bluetooth Class 1
- Auto On/Off
- Battery
- Headphone battery rechargeable - Lithium Ion
- Run Time (Up To)
- 40 hour(s)
- Run Time Details
- Continuous playback (active noise-cancelling on): up to 22 hours , Continuous playback (active noise-cancelling off): up to 40 hours
