Beats Solo 4 On-Ear Wireless Headphones - Slate Blue
Quicklinx: HPDJWS00 Mfr#: MUW43ZM/A
Type: Headphones
Connectivity: Wireless
Colour: Slate blue
Colours:
£165.84 ex VAT
£199.00 inc VAT
Express delivery Order within the next hour for delivery tomorrow
The classic. Made new.
The original go-to headphones for active music lovers are back — and better than ever.
  • Spatial Audio with Dynamic Head Tracking¹
  • Lossless audio via USB-C or 3.5 mm audio cable²
  • Up to 50 hours of Battery Life³
  • Compatible with iOS and Android
Re-engineered for incredible sound.
Upgraded drivers. Rebalanced acoustics. Improved frequency response. Custom-built 40mm transducers minimise electronic artifacts, latency and distortion for extraordinary clarity and range.
Like being surrounded by 64 speakers at once.
Personalised Spatial Audio with dynamic head tracking uses built-in gyroscopes and accelerometers to surround you with sound as you move, creating a truly immersive listening experience.¹
Powerful sound. Ultralight fit.
The ergonomic design was developed with comfort in mind, starting with how light they are — at just 217 grams, you can almost forget you’re wearing them.
Softer than soft.
The UltraPlush ear cushions are designed for durability and a soft, light touch for all-day comfort.
Fits great to sound great.
The carefully balanced flex-grip headband, customisable sliders and ergonomically angled ear cups ensure that Beats Solo 4 is comfortable and stays put to deliver sound optimally to your ears.
Up to 50 hours of battery life.
That’s right — up to 50 hours of battery power.³ That’s a lot of reps. Or flights. Or calls. If you’re low on power, Fast Fuel means charging for just 10 minutes gives up to 5 hours of playback.4
No battery? No problem.
Listening via the 3.5mm audio cable doesn’t require any battery power at all — meaning you can enjoy truly endless playback without ever needing to charge.
High-resolution lossless audio.
Designed with a built-in Digital Analog Converter (DAC), Beats Solo 4 can deliver high-resolution lossless audio.² Plug in via USB-C or 3.5mm audio cable when you want to experience more richly detailed texture in your music.
Apple or Android? Yes.
Whether you’re on iOS or Android, you can enjoy the same seamless compatibility.5
  • One-touch pairing.
  • Automatic pre-pairing across your devices.
  • Find My and Find My Device.
  • Audio Sharing6.
  • Hey Siri7.
Levelling up the iconic style.
Beats Solo 4 comes in new premium colours and finishes, including brushed steel hinges.
Style that travels well.
With a compact foldable design and soft protective case, Beats Solo 4 is built to go everywhere you do.
Exceptional call quality.
Beats Solo 4 has multiple digital beam-forming microphones powered by an advanced voice-learning algorithm for environmental noise suppression. The algorithm was tested in over 7,000 hours of noisy environments to be better able to isolate your voice.
  1. Compatible hardware and software required. Works with compatible content in supported apps. Not all content available in Dolby Atmos. iPhone with TrueDepth camera required to create a personal profile for Spatial Audio, which will sync across Apple devices running the latest operating system software, including iOS, iPadOS, macOS, and tvOS.
  2. Requires compatible lossless content from supported apps/services. Not all content is available in lossless format.
  3. Testing conducted by Apple in March 2024 using pre-production Beats Solo 4 and software paired with iPhone 15 Pro units and pre-release software. The playlist consisted of 358 unique audio tracks purchased from the iTunes Store (256-Kbps AAC encoding). Volume was set to 50%. Testing consisted of full Beats Solo 4 battery discharge while playing audio until Beats Solo 4 stopped playback. Battery life depends on device settings, environment, usage, and many other factors.
  4. Testing conducted by Apple in March 2024 using pre-production Beats Solo 4 units and software paired with iPhone 15 Pro units and pre-release software. The playlist consisted of 358 unique audio tracks purchased from the iTunes Store (256-Kbps AAC encoding). Volume was set to 50%. 10-minute charge testing conducted with drained Beats Solo 4 that were charged for 10 minutes, then audio playback was started until Beats Solo 4 stopped playback. Battery life depends on device settings, environment, usage and many other factors.
  5. Requires an iCloud account and a compatible Apple device running the latest operating system software or a compatible Android device running the latest operating system software with Google Play Services enabled.
  6. Requires an iCloud account and a compatible Apple device running the latest operating system software.
  7. Siri may not be available in all languages or in all areas, and features may vary by area. Compatible device and internet access required. Cellular data charges may apply.
  8. Breakdown of US retail packaging by weight. Adhesives, inks, and coatings are excluded from our calculations of plastic content and packaging weight.
  • Re-engineered for incredible sound
    Upgraded drivers. Rebalanced acoustics. Improved frequency response. Custom-built 40 mm transducers minimize electronic artifacts, latency, and distortion for extraordinary clarity and range.
  • Like being surrounded by 64 speakers at once
    Personalized Spatial Audio with dynamic head tracking uses built-in gyroscopes and accelerometers to surround you with sound as you move, creating a truly immersive listening experience.
  • Powerful sound, ultralight fit
    The ergonomic design was developed with comfort in mind, starting with how light they are - at just 217 grams, you can almost forget you're wearing them.
  • Softer than soft
  • Fits great to sound great
    The carefully balanced flex-grip headband, customizable sliders and ergonomically angled ear cups ensure that Beats Solo 4 is comfortable and stays put to deliver sound optimally to your ears.
  • Up to 50 hours of battery life
    That's right - up to 50 hours of battery power. That's a lot of reps. Or flights. Or calls. If you're low on power, Fast Fuel means charging for just 10 minutes gives up to 5 hours of playback.
  • No battery, no problem
    Listening via the 3.5 mm audio cable doesn't require any battery power at all - meaning you can enjoy truly endless playback without ever needing to charge.
  • High-resolution lossless audio
    Designed with a built-in Digital Analog Converter (DAC), Beats Solo 4 can deliver high-resolution lossless audio. Plug in via USB-C or 3.5 mm audio cable when you want to experience more richly detailed texture in your music.
  • Apple or Android: yes
    Whether you're on iOS or Android, you can enjoy the same seamless compatibility.
  • Leveling up the iconic style
    Beats Solo 4 comes in premium colors and finishes, including brushed steel hinges.
  • Style that travels well
  • Exceptional call quality
Beats Solo 4 - headphones with mic
Headphones - Bluetooth - wireless - 3.5 mm jack, USB-C
Compatibility
iPhone, iPad, iPod, Android phone, Mac, Android tablet
Recommended Use
Portable electronics
Additional Functions
Wireless audio sharing, spatial audio with dynamic head tracking, lossless audio
Slate blue
Headphones Form Factor
On-ear
Foldable
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.3
Sound Output Mode
Stereo
Noise Isolating
Microphone Operation Mode
Beamforming
Controls
Volume, answer/end, play/pause, next/previous track, multiple function button
Intelligent Assistant
Siri - indirect
Compatible Software
Apple Find My, Google Find My Device
1-year warranty
Compatibility
15.8 cm
6.8 cm
17.7 cm
217 g
Slate blue
Recommended Use
One-touch pairing
Audio Output
On-ear
Foldable
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.3
Sound Output Mode
Stereo
Noise Isolating
Diaphragm
40 mm
Adjustable Headband
Fast Fuel technology, built-in Digital Analogue Converter (DAC)
Microphone
Built-in
Beamforming
Remote Control
Controls
Tracking
Sensors
Accelerometer, gyroscope
Connector Type
Headphones (mini-phone stereo 3.5 mm 4-pole) , Headphones (USB Type-C)
Cable
Detachable Cable
Internet of Things (IoT)
Communications Technology
Bluetooth
Siri
Voice Controlled
Indirect
Carrying case, headphones cable, USB-C to USB-C cable
Cable Details
Headphones cable - detachable , USB-C to USB-C cable - detachable
Compatible Software
Bluetooth Class 1
Headphone battery rechargeable - Lithium Ion
Run Time (Up To)
50 hour(s)
Run Time Details
Continuous playback: up to 50 hour(s) , Continuous playback (with 10 min charge): up to 5 hour(s)
Limited warranty - 1 year
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: HPDJ 050459
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £62.50
Ref: HPDJ 050571
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £89.50
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Headphones
Colour: Slate blue
Brand: Beats
Stock Status: Used Stock
