The classic. Made new.
The original go-to headphones for active music lovers are back — and better than ever.
- Spatial Audio with Dynamic Head Tracking¹
- Lossless audio via USB-C or 3.5 mm audio cable²
- Up to 50 hours of Battery Life³
- Compatible with iOS and Android
Re-engineered for incredible sound.
Upgraded drivers. Rebalanced acoustics. Improved frequency response. Custom-built 40mm transducers minimise electronic artifacts, latency and distortion for extraordinary clarity and range.
Like being surrounded by 64 speakers at once.
Personalised Spatial Audio with dynamic head tracking uses built-in gyroscopes and accelerometers to surround you with sound as you move, creating a truly immersive listening experience.¹
Powerful sound. Ultralight fit.
The ergonomic design was developed with comfort in mind, starting with how light they are — at just 217 grams, you can almost forget you’re wearing them.
Softer than soft.
The UltraPlush ear cushions are designed for durability and a soft, light touch for all-day comfort.
Fits great to sound great.
The carefully balanced flex-grip headband, customisable sliders and ergonomically angled ear cups ensure that Beats Solo 4 is comfortable and stays put to deliver sound optimally to your ears.
Up to 50 hours of battery life.
That’s right — up to 50 hours of battery power.³ That’s a lot of reps. Or flights. Or calls. If you’re low on power, Fast Fuel means charging for just 10 minutes gives up to 5 hours of playback.4
No battery? No problem.
Listening via the 3.5mm audio cable doesn’t require any battery power at all — meaning you can enjoy truly endless playback without ever needing to charge.
High-resolution lossless audio.
Designed with a built-in Digital Analog Converter (DAC), Beats Solo 4 can deliver high-resolution lossless audio.² Plug in via USB-C or 3.5mm audio cable when you want to experience more richly detailed texture in your music.
Apple or Android? Yes.
Whether you’re on iOS or Android, you can enjoy the same seamless compatibility.5
- One-touch pairing.
- Automatic pre-pairing across your devices.
- Find My and Find My Device.
- Audio Sharing6.
- Hey Siri7.
Levelling up the iconic style.
Beats Solo 4 comes in new premium colours and finishes, including brushed steel hinges.
Style that travels well.
With a compact foldable design and soft protective case, Beats Solo 4 is built to go everywhere you do.
Exceptional call quality.
Beats Solo 4 has multiple digital beam-forming microphones powered by an advanced voice-learning algorithm for environmental noise suppression. The algorithm was tested in over 7,000 hours of noisy environments to be better able to isolate your voice.
- Compatible hardware and software required. Works with compatible content in supported apps. Not all content available in Dolby Atmos. iPhone with TrueDepth camera required to create a personal profile for Spatial Audio, which will sync across Apple devices running the latest operating system software, including iOS, iPadOS, macOS, and tvOS.
- Requires compatible lossless content from supported apps/services. Not all content is available in lossless format.
- Testing conducted by Apple in March 2024 using pre-production Beats Solo 4 and software paired with iPhone 15 Pro units and pre-release software. The playlist consisted of 358 unique audio tracks purchased from the iTunes Store (256-Kbps AAC encoding). Volume was set to 50%. Testing consisted of full Beats Solo 4 battery discharge while playing audio until Beats Solo 4 stopped playback. Battery life depends on device settings, environment, usage, and many other factors.
- Testing conducted by Apple in March 2024 using pre-production Beats Solo 4 units and software paired with iPhone 15 Pro units and pre-release software. The playlist consisted of 358 unique audio tracks purchased from the iTunes Store (256-Kbps AAC encoding). Volume was set to 50%. 10-minute charge testing conducted with drained Beats Solo 4 that were charged for 10 minutes, then audio playback was started until Beats Solo 4 stopped playback. Battery life depends on device settings, environment, usage and many other factors.
- Requires an iCloud account and a compatible Apple device running the latest operating system software or a compatible Android device running the latest operating system software with Google Play Services enabled.
- Requires an iCloud account and a compatible Apple device running the latest operating system software.
- Siri may not be available in all languages or in all areas, and features may vary by area. Compatible device and internet access required. Cellular data charges may apply.
- Breakdown of US retail packaging by weight. Adhesives, inks, and coatings are excluded from our calculations of plastic content and packaging weight.
Upgraded drivers. Rebalanced acoustics. Improved frequency response. Custom-built 40 mm transducers minimize electronic artifacts, latency, and distortion for extraordinary clarity and range. -
Personalized Spatial Audio with dynamic head tracking uses built-in gyroscopes and accelerometers to surround you with sound as you move, creating a truly immersive listening experience. -
Powerful sound, ultralight fit
The ergonomic design was developed with comfort in mind, starting with how light they are - you can almost forget you're wearing them. -
Softer than soft
The UltraPlush ear cushions are designed for durability and a soft, light touch for all-day comfort. -
The carefully balanced flex-grip headband, customizable sliders and ergonomically angled ear cups ensure that Beats Solo 4 is comfortable and stays put to deliver sound optimally to your ears. -
That's right - up to 50 hours of battery power. That's a lot of reps. Or flights. Or calls. If you're low on power, Fast Fuel means charging for just 10 minutes gives up to 5 hours of playback. -
No battery, no problem
Listening via the 3.5 mm audio cable doesn't require any battery power at all - meaning you can enjoy truly endless playback without ever needing to charge. -
Designed with a built-in Digital Analog Converter (DAC), Beats Solo 4 can deliver high-resolution lossless audio. Plug in via USB-C or 3.5 mm audio cable when you want to experience more richly detailed texture in your music. -
Apple or Android: yes
Whether you're on iOS or Android, you can enjoy the same seamless compatibility. -
Leveling up the iconic style
Beats Solo 4 comes in premium colors and finishes, including brushed steel hinges. -
With a compact foldable design and soft protective case, Beats Solo 4 is built to go everywhere you do. -
- Beats Solo 4 - headphones with mic
- Product Type
- Headphones - Bluetooth - wireless - 3.5 mm jack, USB-C
- Compatibility
- iPhone, iPad, iPod, Mac, Android phone, Android tablet
- Recommended Use
- Portable electronics
- Additional Functions
- Spatial audio with dynamic head tracking, lossless audio, wireless audio sharing
- Pink cloud
- Headphones Form Factor
- On-ear
- Foldable
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.3
- Sound Output Mode
- Stereo
- Noise Isolating
- Microphone Operation Mode
- Beamforming
- Controls
- Volume, play/pause, answer/end, next/previous track, multiple function button
- Intelligent Assistant
- Siri - indirect
- Compatible Software
- Google Find My Device, Apple Find My
- 1-year warranty
- Product Type
- Compatibility
- 15.8 cm
- 6.8 cm
- 17.7 cm
- 217 g
- Pink cloud
- Recommended Use
- One-touch pairing
Audio Output
- On-ear
- Foldable
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.3
- Sound Output Mode
- Stereo
- Noise Isolating
- Diaphragm
- 40 mm
- Adjustable Headband
- Fast Fuel technology, built-in Digital Analogue Converter (DAC)
Microphone
- Form Factor
- Built-in
- Beamforming
Remote Control
- Controls
Tracking
- Sensors
- Gyroscope, accelerometer
- Connector Type
- Headphones (mini-phone stereo 3.5 mm 4-pole) , Headphones (USB Type-C)
Cable
- Detachable Cable
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Communications Technology
- Bluetooth
- Siri
- Voice Controlled
- Indirect
- Included Accessories
- Carrying case, USB-C to USB-C cable, headphones cable
- Cable Details
- Headphones cable - detachable , USB-C to USB-C cable - detachable
- Bluetooth Class 1
- Battery
- Headphone battery rechargeable - Lithium Ion
- Run Time (Up To)
- 50 hour(s)
- Run Time Details
- Continuous playback: up to 50 hour(s) , Continuous playback (with 10 min charge): up to 5 hour(s)
- Limited warranty - 1 year
