Beats Powerbeats3 Wireless Earphones - White
Quicklinx: CCJWWS00 Mfr#: ML8W2ZM/A
Colours:
Take your workout to the next level with Powerbeats3 Wireless earphones, featuring up to 12 hours of battery life to last through multiple workouts and secure-fit earhooks to maximise comfort and stability. With Fast Fuel, a 5-minute charge gives you 1 hour of playback. Sweat and water resistance provides trusted durability and dual-driver acoustics deliver dynamic sound to power your workout.
Wireless the way it should be
Powerbeats3 Wireless are ready to work when you are. They instantly set up -- just power on and hold near your iPhone -- and then simultaneously connect to your Apple Watch, iPad and Mac.* With Class 1 Bluetooth technology, Powerbeats3 Wireless keep up during tough workouts.
Power meets endurance
Bring on the hours of training because Powerbeats3 Wireless are now powered for the long haul with the efficiency of the Apple W1 chip. With up to 12 hours of battery life and an optimised design for improved comfort and immersive sound, you're free to push through the most challenging workouts. Sweat and water resistance provides the necessary durability for strenuous workouts and weather.
Ready whenever
Fast Fuel lets you spend more time charging forward and less time recharging. A quick 5-minute charge generates enough power for a typical hour-long workout so you'll have the confidence that music will be on your side. Use the RemoteTalk to take calls with a built-in mic, play music, adjust volume and activate Siri.
Comfortably unstoppable
An improved ergonomic design makes way for clear, dynamic sound powered by dual-driver acoustics. Powerbeats3 Wireless come with multiple eartips for a personalised and comfortable fit while flexible, secure-fit earhooks optimise stability. The result is authentic, wide-ranging sound with dynamic highs and powerful lows for an immersive listening experience.
*Requires iCloud account and macOS Sierra, iOS 10 or watchOS 3
Highlights:
  • Connect via Class 1 Bluetooth® with your device for wireless workout freedom
  • Up to 12 hours of battery life to power through multiple workouts
  • With Fast Fuel, a 5-minute charge gives you 1 hour of playback when battery is low
  • Sweat and water resistance to handle tough training
  • Flexible, secure-fit earhooks maximise comfort and stability
  • Dynamic, high-performance sound pushes you to the next level
  • Take calls, control your music and activate Siri with RemoteTalk
  • Wireless the way it should be
    Powerbeats3 Wireless are ready to work when you are. They instantly set up — just power on and hold near your iPhone — and then simultaneously connect to your Apple Watch, iPad and Mac.
  • Power meets endurance
    Bring on the hours of training because Powerbeats3 Wireless are now powered for the long haul with the efficiency of the Apple W1 chip. With up to 12 hours of battery life and an optimized design for improved comfort and immersive sound, you’re free to push through the most challenging workouts. Sweat and water resistance provides the necessary durability for strenuous workouts and weather.
  • Ready whenever
    Fast Fuel lets you spend more time charging forward and less time recharging. A quick 5-minute charge generates enough power for a typical hour-long workout so you’ll have the confidence that music will be on your side. Use the RemoteTalk to take calls with a built-in mic, play music, adjust volume and activate Siri.
  • Comfortably unstoppable
    An improved ergonomic design makes way for clear, dynamic sound powered by dual-driver acoustics. Powerbeats3 Wireless come with multiple eartips for a personalized and comfortable fit while flexible, secure-fit earhooks optimize stability. The result is authentic, wide-ranging sound with dynamic highs and powerful lows for an immersive listening experience.
Beats Powerbeats3 - earphones with mic
Earphones - Bluetooth - wireless
Compatibility
iPhone, iPad, iPod
Recommended Use
Portable electronics
White
Headphones Form Factor
In-ear - over-the-ear mount
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Noise Isolating
Microphone
On-cable
Microphone Operation Mode
Mono
Controls
Volume, answer/end
1-year warranty
Compatibility
iPhone, iPad, iPod
White
Recommended Use
Protection
Waterproof, sweat-resistant
Audio Output
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Noise Isolating
In-Cord Volume Control
Microphone
On-cable
Mono
Remote Control
Controls
Volume, answer/end
Carrying case, 4 ear tips
Cable Details
USB charge cable
Headphone battery rechargeable - Lithium Ion
Run Time (Up To)
12 hour(s)
Limited warranty - 1 year
