Beats Powerbeats3 Wireless Earphones - Pop Collection - Pop Blue
Quicklinx: DTM9WS00 Mfr#: MRET2ZM/A
Accessory Type: Earphones
Connectivity: Wireless
Colour: Blue
£141.63 ex VAT
£169.95 inc VAT
Take your workout to another level with the Powerbeats3 wireless earphones, featuring a long battery life to last through multiple workouts and secure-fit ear hooks to maximize comfort and stability. Sweat and water resistance provides trusted durability and dual-driver acoustics deliver dynamic sound to power your workout.
  • Wireless the way it should be
    Powerbeats3 Wireless are ready to work when you are. They instantly set up — just power on and hold near your iPhone — and then simultaneously connect to your Apple Watch, iPad and Mac. With Class 1 Bluetooth technology, Powerbeats3 Wireless keep up during tough workouts.
  • Power meets endurance
    Bring on the hours of training because Powerbeats3 Wireless are now powered for the long haul with the efficiency of the Apple W1 chip. With up to 12 hours of battery life and an optimized design for improved comfort and immersive sound, you’re free to push through the most challenging workouts. Sweat and water resistance provides the necessary durability for strenuous workouts and weather.
  • Ready whenever
    Fast Fuel lets you spend more time charging forward and less time recharging. A quick 5-minute charge generates enough power for a typical hour-long workout so you’ll have the confidence that music will be on your side. Use the RemoteTalk to take calls with a built-in mic, play music, adjust volume and activate Siri.
  • Comfortably unstoppable
    An improved ergonomic design makes way for clear, dynamic sound powered by dual-driver acoustics. Powerbeats3 Wireless come with multiple eartips for a personalized and comfortable fit while flexible, secure-fit earhooks optimize stability. The result is authentic, wide-ranging sound with dynamic highs and powerful lows for an immersive listening experience.
Beats Powerbeats3 - Beats Pop Collection - earphones with mic
Earphones - Bluetooth - wireless
Compatibility
iPhone, iPad, iPod
Recommended Use
Portable electronics
Pop blue
Headphones Form Factor
In-ear - over-the-ear mount
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0
Sound Output Mode
Stereo
Noise Isolating
Noise isolating
Microphone
On-cable
Controls
Volume, answer/end
10.5-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad (5th generation, 6th generation); 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini 2; 3; 4; iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, X, XR, XS, XS Max; iPod touch (6G); Watch
Compatibility
iPhone, iPad, iPod
Pop blue
Recommended Use
Protection
Waterproof, sweat-resistant
Headphones
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0
Sound Output Mode
Stereo
Noise Isolating
In-Cord Volume Control
Microphone
On-cable
Remote Control
Controls
Volume, answer/end
USB charge cable
Carrying case, 4 ear tips
Headphone battery rechargeable - Lithium Ion
Run Time (Up To)
12 hour(s)
Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation, 3rd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, X, XR, XS, XS Max , Apple iPod touch (6G) , Apple Watch
Colour: Blue
Brand: Beats
Price Range Ex VAT: 100 - 150
