Beats Powerbeats Pro 2 - Quick Sand - Grade B
Quicklinx: J8C8WS00 Mfr#: MX733ZM/A/GRADEB
Built for athletes. After relentless testing and refinements, the next-generation Powerbeats Pro 2 is ready for action.
Grade B returned device
Looking for Buds, but want to make your money go further? Try one of our Grade B devices and you’ll find amazing deals on some of the latest and greatest devices.
12 months warranty
Good condition, showing small signs of wear which includes, but not limited to, small/fine scratches and marks.
  • Tried and tested, and tested again
    In search of the perfect fit, over 1,500 hours of rigorous testing with nearly 1,000 athletes were conducted.
  • Stays locked in
    The updated earhook has been rebuilt with a super-light nickel-titanium alloy that is renowned in material design for its exceptional shape memory and flexibility.
  • Heart rate monitoring for workouts
    You want real-time data about your workout performance, and the Powerbeats Pro 2 has accurate heart rate monitoring sensors.
  • Incredible sound
    Powerbeats Pro 2's bespoke acoustic architecture delivers a powerful, balanced sound profile with dynamic range across the frequency curve, all to reproduce the full emotion of your music. Dual-layer drivers minimize distortion and are aligned to each earbud's nozzle for optimal sound delivery. Innovative venting improves bass while reducing pressure for extra comfort.
  • Incredible noise canceling
    For absolute focus, turn on Active Noise Canceling (ANC). Listen in Transparency mode when you need to hear the world around you - like on a run in the city, or biking in traffic.
  • Adaptive EQ is as smart as it sounds
    Adaptive EQ uses advanced inward-facing microphones to continuously scan the fit and seal of your earbuds, analyze what you're hearing, and adjust acoustic frequencies for clear, customized sound.
  • Personalized Spatial Audio
    Powerbeats Pro 2 supports Personalized Spatial Audio with dynamic head tracking for a rich surround-sound experience. It also delivers ultra-low latency Lossless Audio with Apple's Vision Pro, making movies, shows and games feel even more remarkably immersive.
  • Powered by the Apple H2 chip
    The updated sound profile, noise canceling, heart rate monitoring for workouts and exceptional battery life are all enabled by the efficient Apple H2 chip.
  • Sweat- and water-resistant
    Powerbeats Pro 2 is sweat- and water-resistant with an IPX4 rating, so you can go as hard as you want to even in the rain, snow or heat.
  • Stay in command
    Use the on-ear buttons or your voice to control your music, so you can focus on your training without disrupting your flow. Each earbud also has a tactile volume rocker for convenience.
  • Updated mics, clutch call quality
    Each earbud is equipped with a voice accelerometer and three advanced microphones. The improved microphones are more accurate, with an improved signal-to-noise ratio and exceptional voice targeting and noise suppression.
Beats Powerbeats Pro 2 - true wireless earphones with mic
True wireless earphones - Bluetooth
Compatibility
iPhone, iPad, iPod, Android phone, Android tablet, Mac
Recommended Use
Portable electronics - sport
Additional Functions
Transparency mode, spatial audio with dynamic head tracking, wireless audio sharing, lossless audio
Quick sand
Headphones Form Factor
In-ear - over-the-ear mount
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Sound Effects
Adaptive EQ
Microphone Noise Cancelling
Microphones Included
3
Controls
Volume, answer/end, mute, reject call, ANC/transparency, play/pause, next/previous track, voice assistant
Intelligent Assistant
Siri - indirect
Compatible Software
Apple Find My
1-year warranty
True wireless earphones - Bluetooth - wireless
Compatibility
Dimensions & Weight Details
Charging case: 3.4 cm x 6.6 cm x 7.5 cm / 66 g
2.4 cm
4.1 cm
4.5 cm
77.7 g
Quick sand
Body Material
Nickel titanium
Recommended Use
Secure-fit wingtips design, one-touch pairing, on-ear detection
Protection
IPX4, sweat-resistant, water-resistant
Tracking Data
Location
Audio Output
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Sound Effects
Adaptive EQ
Fast Fuel technology, Apple H2 chip, Auto Switch, Auto Pause
Microphone
Built-in
3
Noise Cancelling
Remote Control
Controls
Tracking
Sensors
Heart rate, voice accelerometer, motion-detecting accelerometer, optical sensor
Internet of Things (IoT)
Communications Type
Cloud
Communications Technology
Bluetooth
Siri
Voice Controlled
Indirect
5 pairs of silicone ear tips (XS, S, M, L, XL), charging case
Compatible Software
Apple Find My
Bluetooth Class 1
Auto On/Off
Headphone battery rechargeable - Lithium Ion - - wireless charging
Wireless Charging Standards
Qi
Run Time (Up To)
10 hour(s)
Run Time Details
Continuous playback: up to 10 hours , Continuous playback (with included charging case): up to 45 hours , Continuous playback (with 5 min charge): up to 1.5 hour(s)
Limited warranty - 1 year
