Beats Powerbeats Pro 2 - Electric Orange
Quicklinx: J13SWS00 Mfr#: MX743ZM/A
Type: In-Ear
Connectivity: Wireless
Colour: Electric orange
Colours:
32 left in stock
£165.84 ex VAT
£199.00 inc VAT
Express delivery Order within the next 8 hours for delivery tomorrow
Built for Athletes
After relentless testing and refinements, the next-generation Powerbeats Pro 2 are ready for action.
And they’re the most advanced product we’ve ever developed.
Tried and tested. And tested again.
In search of the perfect fit, we conducted over 1,500 hours of rigorous testing with nearly 1,000 athletes. The result: Powerbeats Pro 2 are our best-fitting headphones – ever.
Heart-rate monitoring for workouts.
You want real-time data about your workout performance, so we built Powerbeats Pro 2 with accurate heart-rate monitoring sensors.
Precision-crafted LED optical sensors pulse light over 100 times per second to measure your blood flow.
All this can be relayed to your favourite fitness apps in real time – and of course you can turn heart rate monitoring off whenever you want.
Stays locked in.
The updated ear hook has been rebuilt with a super-light nickel-titanium alloy that is renowned in material design for its exceptional shape memory and flexibility.
Light like a butterfly
The redesigned Powerbeats Pro 2 are 20% lighter than their predecessor.
Incredible sound. Incredible noise cancelling.
Powerbeats Pro 2 deliver powerful sound for any training environment.
Turn on Active Noise Cancelling (ANC) when you want absolute focus, and experience the best noise cancelling we’ve ever developed.
Listen in Transparency mode when you need to hear the world around you.
Re-engineered acoustics and spatial audio.
Powerbeats Pro 2 have a redesigned acoustic architecture and upgraded venting to enhance your sound and comfort, plus personalised spatial audio with dynamic head tracking to fully immerse you in your music.
Adaptive EQ is as smart as it sounds.
Using the advanced inward-facing microphones, adaptive EQ continuously scans your specific ear shape to optimise your listening experience. The advanced technology analyses what you’re hearing in real time based on the individual fit of your earbuds, then adjusts acoustic frequencies for clear, customised sound.
Up to 45 hours of battery life with the charging case.
And each bud gives up to 10 hours of playback per charge. That’s countless miles or reps. Thanks to Fast Fuel, a five-minute charge gives you up to 90 minutes of playback
Wireless charging case.
Powerbeats Pro 2 are also our very first product that is compatible with wireless Qi charging. The charging case is now 33% smaller for easy portability.
Five ear tip sizes.
For the first time ever, we’ve added a fifth ear tip size to help optimise your personal comfort. Choose from extra-small, small, medium, large and extra-large to find your fit.
Sweat and water resistant.
Powerbeats Pro 2 are sweat and water resistant with an IPX4 rating, so you can go as hard as you want to without interruption, even in the rain, snow or heat.
Elite microphones. Clutch call quality.
Each earbud is equipped with a voice accelerometer and three advanced microphones identical to those used in AirPods Pro 2. The improved microphones are more accurate than any we’ve featured before, with an improved signal-to-noise ratio and exceptional voice targeting and noise suppression.
Next-level voice isolation
Leveraging advanced computational audio and a machine-learning algorithm, voice isolation reduces background noise while isolating and clarifying the sound of your voice during calls.
Stay in command.
Use the on-ear buttons or your voice to control your music, so you can focus on your training without disrupting your flow. Each earbud also has an tactile volume rocker for ultimate convenience.
Powered by the Apple H2 chip.
The updated sound profile, noise cancelling, heart-rate monitoring for workouts and exceptional battery life are all enabled by the efficient Apple H2 chip, the same chip that powers AirPods Pro 2.
What’s in the box
• Powerbeats Pro 2 true wireless earbuds
• Charging case
• Quick Start Guide
• Warranty card
(USB-C to USB-C charging cable not included)
  • Tried and tested, and tested again
    In search of the perfect fit, over 1,500 hours of rigorous testing with nearly 1,000 athletes were conducted.
  • Stays locked in
    The updated earhook has been rebuilt with a super-light nickel-titanium alloy that is renowned in material design for its exceptional shape memory and flexibility.
  • Heart rate monitoring for workouts
    You want real-time data about your workout performance, and the Powerbeats Pro 2 has accurate heart rate monitoring sensors.
  • Incredible sound
    Powerbeats Pro 2's bespoke acoustic architecture delivers a powerful, balanced sound profile with dynamic range across the frequency curve, all to reproduce the full emotion of your music. Dual-layer drivers minimize distortion and are aligned to each earbud's nozzle for optimal sound delivery. Innovative venting improves bass while reducing pressure for extra comfort.
  • Incredible noise canceling
    For absolute focus, turn on Active Noise Canceling (ANC). Listen in Transparency mode when you need to hear the world around you - like on a run in the city, or biking in traffic.
  • Adaptive EQ is as smart as it sounds
    Adaptive EQ uses advanced inward-facing microphones to continuously scan the fit and seal of your earbuds, analyze what you're hearing, and adjust acoustic frequencies for clear, customized sound.
  • Personalized Spatial Audio
    Powerbeats Pro 2 supports Personalized Spatial Audio with dynamic head tracking for a rich surround-sound experience. It also delivers ultra-low latency Lossless Audio with Apple's Vision Pro, making movies, shows and games feel even more remarkably immersive.
  • Powered by the Apple H2 chip
    The updated sound profile, noise canceling, heart rate monitoring for workouts and exceptional battery life are all enabled by the efficient Apple H2 chip.
  • Sweat- and water-resistant
    Powerbeats Pro 2 is sweat- and water-resistant with an IPX4 rating, so you can go as hard as you want to even in the rain, snow or heat.
  • Stay in command
    Use the on-ear buttons or your voice to control your music, so you can focus on your training without disrupting your flow. Each earbud also has a tactile volume rocker for convenience.
  • Updated mics, clutch call quality
    Each earbud is equipped with a voice accelerometer and three advanced microphones. The improved microphones are more accurate, with an improved signal-to-noise ratio and exceptional voice targeting and noise suppression.
Beats Powerbeats Pro 2 - true wireless earphones with mic
True wireless earphones - Bluetooth
Compatibility
iPhone, iPad, iPod, Android phone, Android tablet, Mac
Recommended Use
Portable electronics - sport
Additional Functions
Transparency mode, spatial audio with dynamic head tracking, wireless audio sharing, lossless audio
Electric orange
Headphones Form Factor
In-ear - over-the-ear mount
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Sound Effects
Adaptive EQ
Microphone Noise Cancelling
Microphones Included
3
Controls
Volume, answer/end, mute, reject call, ANC/transparency, play/pause, next/previous track, voice assistant
Intelligent Assistant
Siri - indirect
Compatible Software
Apple Find My
1-year warranty
True wireless earphones - Bluetooth - wireless
Compatibility
Dimensions & Weight Details
Charging case: 3.4 cm x 6.6 cm x 7.5 cm / 66 g
2.4 cm
4.1 cm
4.5 cm
77.7 g
Electric orange
Body Material
Nickel titanium
Recommended Use
Secure-fit wingtips design, one-touch pairing, on-ear detection
Protection
IPX4, sweat-resistant, water-resistant
Tracking Data
Location
Audio Output
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Sound Effects
Adaptive EQ
Fast Fuel technology, Apple H2 chip, Auto Switch, Auto Pause
Microphone
Built-in
3
Noise Cancelling
Remote Control
Controls
Tracking
Sensors
Heart rate, voice accelerometer, motion-detecting accelerometer, optical sensor
Internet of Things (IoT)
Communications Type
Cloud
Communications Technology
Bluetooth
Siri
Voice Controlled
Indirect
5 pairs of silicone ear tips (XS, S, M, L, XL), charging case
Compatible Software
Apple Find My
Bluetooth Class 1
Auto On/Off
Headphone battery rechargeable - Lithium Ion - - wireless charging
Wireless Charging Standards
Qi
Run Time (Up To)
10 hour(s)
Run Time Details
Continuous playback: up to 10 hours , Continuous playback (with included charging case): up to 45 hours , Continuous playback (with 5 min charge): up to 1.5 hour(s)
Limited warranty - 1 year
Type: In-Ear
Brand: Beats
Stock Status: While stocks last
Stock Status: Clearance
