The Beats by Dr. Dre Powerbeats2 Wireless headphones are exceptionally light and deliver the power of dual-driver acoustics to propel you through rigorous workouts. The IPX-4 sweat- and water-resistance rating means Powerbeats2 Wireless are tough from ear bud to the tangle-free cable wrap around. There's also over-molding on the RemoteTalk for a non-slip grip when you're changing volume, switching tracks, and making hands-free calls.
Performance and power
The Beats by Dr. Dre Powerbeats2 Wireless headphones are exceptionally light and deliver the power of dual-driver acoustics to propel you through rigorous workouts. -
Designed to endure
The IPX-4 sweat- and water-resistance rating means Powerbeats2 Wireless are tough from ear bud to the tangle-free cable wrap around. There's also over-molding on the RemoteTalk for a non-slip grip when you're changing volume, switching tracks, and making hands-free calls. -
More freedom
From the street to the court, Powerbeats2 Wireless gives you the freedom to take your workout anywhere. Wireless Bluetooth lets you connect up to 30 feet from your Bluetooth-enabled device - so you can move freely and stay focused on your workout. A rechargeable battery with long playback gives you the power to endure to the end. -
Made to perform
Designed with your active life in mind, Powerbeats2 Wireless is lightweight and compact with a flexible ear hook to ensure a comfortable and secure fit.
- Beats Powerbeats2 Wireless - earphones with mic
- Product Type
- Earphones - Bluetooth - wireless
- Red
- Headphones Form Factor
- In-ear - over-the-ear mount - binaural
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Sound Output Mode
- Stereo
- Microphone
- On-cable
- 2-year warranty
- Product Type
- 43.7 cm
- Length
- 50 cm
- 24 g
- Red
- Protection
- Waterproof
- Max Operating Distance
- 9.14 m
Audio Output
- Wireless
- Bluetooth
- Sound Output Mode
- Stereo
Microphone
- On-cable
Wireless Link
- Transmission Range
- 9.14 m
- Included Accessories
- Hard case, 4 pairs of ear tips, cable clip
- Cable Details
- Micro-USB cable
- IPX4
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 6 hour(s)
- Limited warranty - 2 years
