The Beats Pill speaker is lightweight enough to take along and set up anywhere. It's also small enough to fit in whatever bag or luggage you're carrying out the door. So you'll always have high-quality sound wherever you are.
The new surround sound. Just tap two Pills together twice to make one Pill the left output and the other the right.
One charge gives you many hours of continuous play. Charge your Pill almost anywhere, from your Mac's USB port to any outlet.
Totally portable
The Beats Pill speaker is lightweight enough to take along and set up anywhere. It's also small enough to fit in whatever bag or luggage you’re carrying out the door. So you’ll always have high-quality sound wherever you are. -
Tap to amplify
Two is louder than one. Sync two Pills by tapping them together to play the same song. -
Tap to stereo
The new surround sound. Just tap two Pills together twice to make one Pill the left output and the other the right. -
Rechargeable battery
One charge gives you up to seven hours of continuous play. Charge your Pill almost anywhere, from your Mac’s USB port to any outlet.
- Beats by Dr. Dre Pill 2.0 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth, NFC
- Speaker Details
- Speaker - stereo x 2 - active
- Red
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - Lithium Ion
- 19 cm 4.5 cm
- 310 g
- Product Type
- Hands-Free Function
- Enclosure Colour
- Red
Speaker System
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth, Near Field Communication (NFC)
- Transmission Range
- 10 m
- Controls
- Power on/off, volume, call answer, play/pause, next track, previous track
- Additional Features
- Daisy-chain capability
Speaker System Details
- Speaker Details
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , Audio line-out (mini-phone stereo 3.5 mm) , DC power output (4 PIN USB Type A)
- Included Accessories
- Carrying case, AC power adaptor, audio cable, USB cable
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - Lithium Ion
- Run Time (Up To)
- 7 hour(s)
- 19 cm
- 4.5 cm
- 310 g
