Beats Pill 2.0 Speaker - Pink
Quicklinx: B73FWS00 Mfr#: MH9M2B/A
Colours:
The Beats Pill speaker is lightweight enough to take along and set up anywhere. It's also small enough to fit in whatever bag or luggage you're carrying out the door. So you'll always have high-quality sound wherever you are.
The new surround sound. Just tap two Pills together twice to make one Pill the left output and the other the right.
One charge gives you many hours of continuous play. Charge your Pill almost anywhere, from your Mac's USB port to any outlet.
  • Totally portable
    The Beats Pill speaker is lightweight enough to take along and set up anywhere. It's also small enough to fit in whatever bag or luggage you’re carrying out the door. So you’ll always have high-quality sound wherever you are.
  • Tap to amplify
    Two is louder than one. Sync two Pills by tapping them together to play the same song.
  • Tap to stereo
  • Rechargeable battery
    One charge gives you up to seven hours of continuous play. Charge your Pill almost anywhere, from your Mac’s USB port to any outlet.
Beats by Dr. Dre Pill 2.0 - speaker - for portable use - wireless
Speaker - for portable use
Speaker Type
Active
Amplifier
Integrated
Bluetooth, NFC
Speaker Details
Speaker - stereo x 2 - active
Pink
Power Options
USB charging
Speaker battery rechargeable - Lithium Ion
19 cm 4.5 cm
310 g
Hands-Free Function
Enclosure Colour
Pink
Speaker System
Speaker Type
Active
Amplifier
Integrated
Bluetooth, Near Field Communication (NFC)
Transmission Range
10 m
Controls
Power on/off, volume, call answer, play/pause, next track, previous track
Additional Features
Daisy-chain capability
Speaker System Details
Speaker Details
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , Audio line-out (mini-phone stereo 3.5 mm) , DC power output (4 PIN USB Type A)
Carrying case, AC power adaptor, audio cable, USB cable
Power Source
Options
USB charging
Rechargeable - Lithium Ion
Run Time (Up To)
7 hour(s)
19 cm
4.5 cm
310 g
