Beats Pill - Statement Red
Quicklinx: HRTMWS00 Mfr#: MWQW3ZM/A
Speaker Type: Speaker
Connection: Wired, Wireless
Colours:
14 In Stock
£123.34 ex VAT
£148.00 inc VAT
Express delivery Order within the next 7 hours for delivery tomorrow
Small enough to deliver your daily dose of music wherever you go, the Pill brings the Beats by Dr. Dre sound to your iPhone, iPad or iPod touch. Music, calls and films never sounded so good.
  • Tap-to-pair with NFC technology for easy and instant Bluetooth 2.1 audio and supports SBC and AAC Codecs for high-quality streaming
  • Provides clear, full-range sound delivered in a portable, lightweight package
  • Internal microphone for Bluetooth call functionality; take calls without touching your iPhone
  • Use the Aux input for other MP3 players, phones, PCs or anything with an analog output for optimal sound from all devices
  • Use the line out feature for easy connection to an external speaker system
  • Small size, big sound
    Despite its compact size, the Pill delivers powerful sound. It's easy to enjoy soaring highs and deep, booming bass in every room of the house. The Pill is wireless and cord-free.
  • Change tracks from your iPhone
    Control your music via Bluetooth from your iPhone, iPad, iPod touch or MacBook from up to 30 feet away. The Pill frees you to roam, which means you'll always have high quality sound near or far.
  • Totally portable
    The Pill is lightweight so it won't slow you down and is small enough to fit in whatever you're carrying out the door.
  • Bluetooth conferencing
    Take that call thanks to the Pill's Bluetooth capability and internal microphone. It makes talking on the phone easier and better sounding than ever before.
Beats Pill - speaker - for portable use - wireless
Speaker - for portable use
Protection
Dust-resistant, water-resistant
Speaker Type
Active
Amplifier
Integrated
Bluetooth
Speaker Details
Speaker - stereo x 2 - active
Statement red
Sound Effects
Stereo mode
Power Options
USB charging
Speaker battery rechargeable - Lithium Ion
21.9 cm x 7.1 cm x 7 cm
680 g
1-year warranty
Multi-speaker connectivity
Hands-Free Function
Microphone
Protection
Enclosure Colour
Statement red
Enclosure Material
Silicone covered
Design Features
20-degree upward tilt design
Speaker System
Speaker Type
Active
Magnet Type
Neodymium
Multiroom
Amplifier
Integrated
Sound Effects
Stereo mode
Bluetooth 5.3
Compatible Software
Apple Find My
Controls
Play/pause, volume, power on/off
App-Controlled
Internet of Things (IoT)
Communications Technology
Bluetooth 5.3
Speaker System Details
Speaker Details
Driver Details
Speaker: woofer driver - racetrack , Speaker: tweeter driver
Connector Type
USB (24 pin USB-C)
Lanyard, USB-C cable
IP67, Bluetooth Class 1
Supported Host Device OS
iOS, Android
Power Source
Options
USB charging
Rechargeable - Lithium Ion
Run Time (Up To)
24 hour(s)
21.9 cm
7.1 cm
7 cm
680 g
Limited warranty - 1 year
Connection: Wired
Connection: Wireless
Brand: Beats
