Small enough to deliver your daily dose of music wherever you go, the Pill brings the Beats by Dr. Dre sound to your iPhone, iPad or iPod touch. Music, calls and films never sounded so good.
- Tap-to-pair with NFC technology for easy and instant Bluetooth 2.1 audio and supports SBC and AAC Codecs for high-quality streaming
- Provides clear, full-range sound delivered in a portable, lightweight package
- Internal microphone for Bluetooth call functionality; take calls without touching your iPhone
- Use the Aux input for other MP3 players, phones, PCs or anything with an analog output for optimal sound from all devices
- Use the line out feature for easy connection to an external speaker system
Small size, big sound
Despite its compact size, the Pill delivers powerful sound. It's easy to enjoy soaring highs and deep, booming bass in every room of the house. The Pill is wireless and cord-free. -
Change tracks from your iPhone
Control your music via Bluetooth from your iPhone, iPad, iPod touch or MacBook from up to 30 feet away. The Pill frees you to roam, which means you'll always have high quality sound near or far. -
Totally portable
The Pill is lightweight so it won't slow you down and is small enough to fit in whatever you're carrying out the door. -
Bluetooth conferencing
Take that call thanks to the Pill's Bluetooth capability and internal microphone. It makes talking on the phone easier and better sounding than ever before.
- Beats Pill - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Protection
- Dust-resistant, water-resistant
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth
- Speaker Details
- Speaker - stereo x 2 - active
- Statement red
- Sound Effects
- Stereo mode
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - Lithium Ion
- 21.9 cm x 7.1 cm x 7 cm
- 680 g
- 1-year warranty
- Product Type
- Multi-speaker connectivity
- Hands-Free Function
- Microphone
- Protection
- Enclosure Colour
- Statement red
- Enclosure Material
- Silicone covered
- Design Features
- 20-degree upward tilt design
Speaker System
- Speaker Type
- Active
- Magnet Type
- Neodymium
- Multiroom
- Amplifier
- Integrated
- Sound Effects
- Stereo mode
- Bluetooth 5.3
- Compatible Software
- Apple Find My
- Controls
- Play/pause, volume, power on/off
- App-Controlled
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Communications Technology
- Bluetooth 5.3
Speaker System Details
- Speaker Details
- Driver Details
- Speaker: woofer driver - racetrack , Speaker: tweeter driver
- Connector Type
- USB (24 pin USB-C)
- Included Accessories
- Lanyard, USB-C cable
- IP67, Bluetooth Class 1
- Supported Host Device OS
- iOS, Android
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - Lithium Ion
- Run Time (Up To)
- 24 hour(s)
- 21.9 cm
- 7.1 cm
- 7 cm
- 680 g
- Limited warranty - 1 year
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HRTM 051050 Condition: Customer return - item has been repaired under warranty by the manufacturer please note serial numbers dont match due to replacement device. THIS ITEM HAS NO CHARGING CABLE |
£66.83 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
