Completely redesigned, the Beats Studio over-ear headphones are even lighter, stronger, and more comfortable, and more precise than the original world-famous design. They deliver powerful, re-engineered sound alone with Adaptive Noise Canceling, a 20-hour rechargeable battery, and Remote Talk controls.
Grade B returned device
Looking for Buds, but want to make your money go further? Try one of our Grade B devices and you’ll find amazing deals on some of the latest and greatest devices.
12 months warranty
Good condition, showing small signs of wear which includes, but not limited to, small/fine scratches and marks.
Beats custom acoustic platform
Beats Studio Buds + custom acoustic platform packs powerful, balanced sound in a sophisticated, pocketable design. Reengineered acoustic venting improves audio precision and gently relieves pressure for a more comfortable all-day fit. Each bud is equipped with a two-layer transducer that flexes to deliver cleaner bass and ultra-low distortion. So whether you're listening to music or taking calls, Studio Buds + deliver rich, immersive sound wherever you go. -
Active Noise Canceling and Transparency Mode
At the touch of a button, two dynamic listening modes let you choose whether to keep the world out or let it in. Active Noise Canceling (ANC) has been engineered to adapt to your personal fit, neutralizing unwanted external noise. Easily switch to Transparency mode when you need awareness of the world around you. -
More music, less charging
With up to 36 hours of total battery life including 27 hours from the sleek, pocket-sized charging case and up to 9 hours from the earbuds, Beats Studio Buds + are ready to go whenever you are. Find yourself low on battery? A 5-minute Fast Fuel charge provides an hour of additional use² so you get more music, podcasts, and calls between every charge. -
Enhanced Apple and Android compatibility
Beats Studio Buds + offer a robust set of Apple and Android features including one-touch pairing and "Find My" device. -
One-touch pairing
Easy, one-touch setup instantly pairs with every device in your iCloud account. -
"Hey Siri"
Simply say "Hey Siri" to activate your voice assistant. -
Over-the-air updates
Receive software updates and features automatically. -
Audio Switch
Seamlessly transition audio between your Android, Chromebook, and other compatible devices.
- Beats Studio Buds + - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Compatibility
- iPhone, iPad, iPod, Android phone, Mac, Android tablet
- Recommended Use
- Portable electronics
- Additional Functions
- Transparency mode
- Transparent
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Sound Output Mode
- Stereo
- Sound Effects
- Balanced Sound
- Active Noise Canceling
- Controls
- ANC/transparency, multiple function button
- Intelligent Assistant
- Siri
- 1-year warranty
- Product Type
- True wireless earphones - Bluetooth - wireless
- Compatibility
- Transparency mode
- Dimensions & Weight Details
- Charging case: 5.1 cm x 7.2 cm x 2.55 cm / 49 g
- 1.85 cm
- 2.05 cm
- 1.5 cm
- 5 g
- Transparent
- Recommended Use
- Over the air updates, one-touch pairing
- Protection
- IPX4, sweat-resistant, water-resistant
- Tracking Data
- Location
Audio Output
- In-ear
- Connectivity Technology
- Wireless
- Bluetooth
- Sound Output Mode
- Stereo
- Sound Effects
- Balanced Sound
- Active Noise Cancelling Technology
- Adaptive Noise Cancelling
- Fast Fuel technology, Google Fast Pair
Microphone
- Form Factor
- Built-in
Remote Control
- Controls
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Siri
- Included Accessories
- 4 pairs of ear tips (XS, S,M, L), charging case, USB-C to USB-C charging cable
- Cable Details
- USB-C to USB-C cable
- Bluetooth Class 1
- Battery
- Headphone battery rechargeable - Lithium Ion
- Run Time (Up To)
- 9 hour(s)
- Run Time Details
- Continuous playback (with included charging case): up to 36 hours , Continuous playback: up to 9 hours
- Limited warranty - 1 year
